Question about JVC AV-27230 27" TV
Picture partially cropped at bottom of screen
When a weather advisroy scrolls along the bottom of my tv, the top half of the message is cut off so it can't be read.
There doesn't appear to be any way to "shrink" the picture so it all fits on the screen.
    Novelist:
  • 192 Answers
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Posted on Dec 24, 2007
    Problem Solver:
  • 7 Answers
I have an Sharp Aquos 45D65U TV and had the same problem. Turns out somebody had pressed the "View Mode" button on the remote and set it to Zoom. Don't know if you have the capability to change these settings using your TV remote but thought I would pass this along just in case.
Posted on May 02, 2009
Tv is not showing complete picture....some things are cut off
Change the aspect ratio.this can usually be done via the remote or through the tv menu.normal view for most wide screens is wide 16:9 but if you have zoom or crop black bars then you may lose parts of playback.
Feb 19, 2015 | Vizio L37 Television
The picture is to ig for the screen in any mode - i have it on full and it cuts everything off teh top and bottom sony bravia
try checking the aspect ratio settings on the device feeding the tv if applicable, i.e set top box, DVD player, etc
Ensure the settings match the tv type, e.g, 16:9 for a widescreen tv. 4:3 may cause cropping of the top/ bottom of the picture if this is set
Jul 02, 2010 | Televison & Video
Picture is cut off top and bottom (Infocus 7210 projector)
try different ratios, also reflash firmware and lastly try new cables.
Jul 14, 2010 | InFocus ScreenPlay 7210 Multimedia...
27'' lxi reduced picture
This is a problem with the vertical circuit and can be as simple as poor solder connections within that circuit or defective parts. If you have no experience with soldering or TVs, this should go to a service shop. Expect a parts cost in the $30-$40 range for and IC +/or capacitors. If you'd like to attempt this yourself, please supply the exact make and model so I can post the parts required along with additional instructions. Please note that TVs contain potentially dangerous high voltages even when unplugged.
Thanks,
Dan
Mar 15, 2010 | Televison & Video
Picture too big
It seems as if your tv is in "crop", "Zoom", or "full" mode. Select letterbox, normal, or full-screen mode. Look in the manual for exact instructions.
Jul 15, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Top and bottom of the picture is cut off.
look for a button on the remote control that says, "pic size"," zoom","aspect" and scroll through until you get to 16x9, full , fill screen . i can't remember what this model states on the screen.
Feb 19, 2009 | LG 42PC3D 42 in. Plasma Television
Philips 42PF7320A cropping issue
Pete,
When using a hd connection on a philips tv and (I am assuming this is the case) the tv disables the format features on the tv and only lets you select widescreen and automatic, if you are using hd adjust the picture size from the cable/satellite box, look for it in the box's menu system or on the remote, it is usually labeled, aspect ratio, zoom, format or something to that nature, hope I helped you
Aug 20, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Adjusting screen size
Make sure you dont have picture cropping on in your settings. If you do, it will crop about an inch or more off all sides of your picture.
Feb 13, 2008 | Konka KDL32AT23U 32 in. LCD Television
Picture crops at top and bottom of screen
I assume you have used the "wide function" on your remote to verify you are not in "zoom" mode? Other than that I can't be much help.. Sorry Roger
May 05, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Picture not fitting on screen
if your tv has a warranty take it back to where you you bought it.or check if your remote has the zoom feature,if it does zoom it back.or else you will have to call the repair man to program it for you.
Mar 23, 2007 | JVC AV-29LX 29" TV
JVC AV-27230 27" TV Logo
729 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
