Last month Building contractor was working in my area and disrupted telephone service with his backhoe. ( telephone lines are burried underground). Service has been restored but ever since the mishap are modem reports very slow access. The telephone company would like documentation of the access speed becouse they belive all the problems have been addressed. What do you recommend a way to demonstrate to the telephone company that there is still a problem
    Brigadier General:
  • 10,406 Answers
Try: http://www.speedtest.net from your computer.
Get a neighbour to try it on their computer (assuming that they have
DSL access, not cable-modem access, and assuming that pay the same amount/month for the DSL service, i.e.,"lite" versus "lite", "high-speed" versus "high-speed".
Or, if you have a laptop, connect your computer to your neighbour's DSL-service, and run SpeedTest.
Posted on Oct 09, 2009
    Novelist:
  • 171 Answers
Most ISPs have speed test programs on their site.
You can uses their system or this one:
This page gives you some really good advice about collecting information from your modem / router to give to the ISP concerning your modem's operation:
http://www.kitz.co.uk/adsl/linestats.htm#how_linestats
Please vote if this has been of any help to you
Posted on Oct 08, 2009
All 4 hand units say "line in use" How do exit tis situation? hand units model KX-TGA410, baseunit KX-TGA131
A "Line in Use" message generally means that there is no dial tone detected. Assuming that all of the handsets are in Standby and any other phones are connected to that line are also on their hooks, then you need to determine why the base isn't getting a dial tone. This can be an inside or outside wiring problem.
I like to use an old wired telephone for testing since power isn't required to use the phone. You also need another RJ-11 telephone wire. Try connecting a new RJ-11 wire between the KX-TGA131 base and the phone jack. If there is a dial tone with the new cable, you had a bad cable. If not, try the alternate phone. If the test phone has a dial tone, then the KX-TGA131 has failed or has a power problem. If the phone is under warranty, contact Panasonic.
If neither phone has a dial tone, take your test phone to another jack connected to the same phone line (number), if available. If you have a dial tone here, then the problem is in the first jack or the wiring to the jack. You can try to repair the jack yourself. Remove the cover plate and look at the jack. If any wires are loose, reconnect them to their appropriate location. See http://www.lanshack.com/wire_phone_jack.aspx for the usual patterns. There are two types of telephone jacks, keystone and screw terminals. For the keystone type, you need a punch-down tool (available at many hardware stores in the electrical section) to put the wires back in place. Do not strip the individual conductors before using the punch down tool. For screw terminals, strip the wire before securing it under the screw.
If you do not have another jack or there is no dial tone at the second jack, find the incoming telephone service box. Open the box and check the wiring. If you find an RJ-11 jack, plug in your test phone and listen for a dial tone. If there is a dial tone, you have a wiring problem. Check the jacks as above. You may want to have someone else check the wiring in the walls if there are no broken/loose wires in the jacks. Your telephone company will usually offer the service for a fee.
If you can't test the phone line at the service box or there is no dial tone at the service box, contact your telephone company. They will test the service box and should repair outside issues for free. (Some providers are trying to avoid copper repairs.)
If you have DSL, you may need to check the line filter. This filter can disrupt the dial tone when it fails. If the filter is in the interior, you are responsible for the replacement. In my service area, the DSL filter was in the service box so my telephone company repaired it.
I hope this helps.
(I've had no line issues several times. Sometimes, it was the result of a contractor cutting through underground lines. With copper wire, rodents sometimes damaged those underground wires. Once it was simply an issue of a contractor who'd left one wire loose after upgrading the service.)
Aug 26, 2017 | Lands Phones
How deep to dig a french drain side of a driveway
It all depends on the soil conditions, you want to consider the size of your gravel that you use for your french drain and next thing is,
few days before you start to dig your drainage make sure you should contact your local utility company and driveway contractors. Recently, my husband and I just moved into a new house in Long Island area, and I wanted to install a French drain which would help me to hold water. So I got in contact with the local utility company and driveway Long Island contractors to have all the underground utility lines of our property which are located and marked.
Apr 11, 2015 | Plumbing
Which deck building contractor is best to hire in Virginia?
For deck building you can check Paragon remodeling contractor work from here: http://www.paragonremodeling.com/deck-portfolio/index.html. These deals in North Virginia area.
Sep 21, 2013 | IMSI Software Turbo Floorplan Instant Deck...
What type of pipe should I use to replace my broken underground water line. I live in the Atlanta, GA area.
You will need to check on building codes. Copper is usually best from meter to house.
Feb 25, 2012 | Plumbing
When a call comes in it rings one time then stops
This is often caused by a partial short on the phone line. I would first test the line at the incoming interface. If this is a standard phone line(not from a cable company or broadband provider), there is usually an outside interface box where the phone line connects to the building wiring. Open the right side of the box with a screwdriver. In this box there is typically a short line cord plugged into a modular jack(test jack), if you unplug this line cord and connect a standard phone, you will be connected to the phone line but isolated from the building wiring. Make a test call to your number with the standard phone connected to the test jack and if the problem continues then the trouble is on the phone service provider's side and you will need to report the trouble to your service provider. If the trouble does not occur with the phone connected to the test jack, then the trouble is on the building side. To find where the trouble is on the building side you will need to use a process of elimination to test each of the outlets, line cords, telephones and cabling to determine where the short is. This process can often take a lot of time and patience to find the trouble. It may be best to call a telephone tech at this point. If your service is from a cable company or broadband provider, then you will need to test the line at the equipment that converts the cable or broadband into dialtone to determine if the trouble is on the service provider side or the building wiring side. Send a comment if you need more information on finding the trouble in your building wiring, outlets or telephones.
Mar 27, 2011 | Panasonic KX-TGA510 Cordless Phone
Hi, I’m facing one issue with D-Link (DCM-202) Modem from last week. The internet connection frequently disconnecting with interval time less than 10 min. I have checked with service provider COM CAST...
Is this a new issue or a recent harware/cable change or did this use to work and now has the disconnect issues.
Ensure that your cable has NO Splitters (especialy outside) from the Drop outside to your modem.
Check all cableing between Computer and Modem to Cable Drop.
You can also look at the Modem Status Page to check your UpStream and DownStream signals. You may have to have someone come out to check out the line running from your house to the pole (or pedestal if its underground)? Many factors can cause an outside cable to deteriorate, and when that happens you can end up with alot of signal leakage and frequent disconnects. And that goes for both overhead and underground lines. Good Luck, and post back if you need more help. (try to include your Modem Status Logs)
Jan 02, 2011 | D-Link (DCM-202) Modem
My Meridian M7310 phone system is unable to receive or give out going calls on Line 3 only. In addition there is no dial tone on that line only. The other 4 lines are working great. I have already gone to...
Either the line from the telephone company is out or the line port in the line card is defective. The easiest way to determine if its one or the other is to report the line trouble to the telephone company. they'll check the line up to where it comes into the building, and if theres a problem on thier side they'll get it back in service. If the report the line is good to the building, then you'll need to call your telephone system service technician.
Jul 28, 2010 | NorStar Meridian M7310 Phone
Vtech model 2656 caller id is not working. How can I fix this?
Found this on the VTECH support site regarding your model:
Tip 1 of 1
Caller ID and Call Waiting ID are subscription services, available from most local telephone service providers. You must subscribe to these services in order for the features to work on your phone. Contact your local telephone service provider for more information.
In addition, your caller must be calling from an area that supports caller ID.
Both you and your caller’s telephone service provider must use compatible caller ID systems.
If you subscribe to DSL service for this telephone line, DSL filters must be plugged into EVERY phone jack that has a phone. The DSL signal can cause caller ID disruption, static, noise and other issues on your line. DSL filters block the high frequency DSL signals from being transmitted to the telephone. If you are not using the DSL filters provided by the telephone company, this will cause static/noise and possibly caller id issues on your phones.
In most cases, we recommend you connect the plug end of the DSL filter into the telephone jack, then connect a telephone cord between the filter and your phone.
Please contact your service provider to obtain DSL filters and installation information.
Caller ID and Call Waiting ID may not be available for every call. Common reasons are incompatibilities between your and your caller’s service, transmission errors and answering calls before the ID data is received.
In addition if you would like to contact them or get more info on your phone, then use this link:
http://www.vtechphones.com/vtechui/support/faq_index.cfm
Nov 22, 2009 | Vtech VT 2656 Expandable Cordless DSS...
Compressor won't come on, thus A/C is not working.
Tell your contractor that you are notifying the local building inspector. He will not like this. I hope he applied for a permit to do the install. If he did, tell your local building department and demand that they activate the contractors bond to pay for another contractor to complete the job. And/or call the local Goodman distributor and let them know how dissatisfied you are with that particular contractor that they are selling to. See if they can help you. Worst case scenario, accept your loss and call another contractor. I would write a letter to the local newspapers editor and the better business bureau regarding this shady contractor. Put an add in the newspaper notifying everyone what happened to you. Put a sign in your front yard stating DO NOT USE THIS CONTRACTOR
This contractor can not afford to have the bad publicity that you can inflict upon him. Call him ten times a day. Call him at 3 AM every night. Haunt him.
Good luck........
May 02, 2009 | Heating & Cooling
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
