Question about HP Pavilion dv2000t Notebook
Do faulty chipsets on motherboards happen over time or are they a fault which will have been there from the start?
  • 56 Answers
Happen over time due to heat and dust build up. Both are major killers of laptop components. Sometimes the fault was there from the beginning from got full exposed over time by the above heat and build ups.
Posted on Oct 12, 2009
    Problem Solver:
  • 6 Answers
Most electronic chips that fail, will fail either when they are first used, or within 90 days. Failues after this are ususally caused by overheating which is usually caused by a bad fan or by too much dust inside the pc. I vacuum out the inside of my pc twice a year (when I change my clocks).
Posted on Oct 08, 2009
Bios rom checksum error
Hi, the download site for the mainboard is here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D101GGC
I think you have change the battery on the mainboard:
Its a 2032 watch type battery 3 volts.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
It could also be a fault in the ram memory or the cpu.
Aug 22, 2011 | Intel D101GGC Motherboard
Computer does not boot up anymore after system being idle over the weekend. No response from BIOS. Second time this happened within 2 weeks.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 26, 2011 | Intel IB840 Series Pentium 4 865G Chipset...
When I turn on the computer this on the HD for fews seconds and then restart but never ever appear nothing on the screen.
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 13, 2010 | HP Pavilion dv9000 Motherboard
On starting the color of monitor screen got parallel lines and colors screen becaim faint due to this computer became hanged. Some times it works properly for some minutes but laterly the same fault...
Video corruption - the video chip is faulty . Because the video chip is part of the chipset it means that the chipset is faulty, which causes the pc to crash.
Sorry, the motherboard is dying, you will have to replace it.
Nov 24, 2010 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
I have dh55tc, i7 860, 4gb transcend ram, xfx hd 5770, tagan stonerock -u37 600w psu, Its assembled in March 2010 & ran fine for 5 months. One day while watching movie it suddenly froze, i restarted...
3 beeps means that it's a RAM fault. If your memory worked just fine in another pc then it's the fault of the memory controller of the chipset on the motherboard - either the memory slot is loose (move the stick in the slot and try again) or the chipset itself is failing. That can't be fixed, the mobo is dead, replace it.
Nov 19, 2010 | Intel DH55TC Motherboard
Same problem, once it shuts down it will not boot for a long time
Friend, your hard drive is disconnected.connect it properly.
Jul 25, 2009 | IBM ThinkPad T40 2373 Notebook
Tohiba l300 completely blank screen
If the screen is always blank, even on startup , before loading Windows, than this is probably an hardware fault.
Try unplugging the laptop and removing the battery at the same time, wait 5 minutes, then put the laptop together. This will drain power and reset the laptop.
If that does not work, and you get no pictuer under any circumstance , then there is a fault.
If the screen is black with no light , then it is either a faulty inverter or a problem on mainboard.
If the screen is all lit, but is blank with no signal, then it is often because of a bad LCD ribbon cable , but can be again the video chipset on the motherboard.
Try connecting to an external monitor, if it works then problem is restricted to LCD/inverter and ribbon cable, if it does not work on external monitor is usually a bad video chipset on motherboard.
May 06, 2009 | Toshiba Satellite Pro L300 Notebook
Motherboard problem..
It sounds like the front panel wire has either come loose from the motherboard or is plugged into the wrong spot. Recheck the motherboard to see if the wires are in the right place & not loose. Hope this helps.
Dec 27, 2008 | ASUS A8N-SLI Deluxe Motherboard
Advent T100 All in one system
PCbroke
Yes, you may have a faulty MOBO, time to replace it.
it is suppose to sustain power and voltage. other that this, is a fault.
good luck
Jul 18, 2008 | Computers & Internet
C1 Fault
c1 refers to a memory fault, so check that the memory timings according to the manual are correct or that the memory is not faulty.
Jul 25, 2007 | EPoX EP-8RDA3I Motherboard
HP Pavilion dv2000t Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
