Question about Samsung SCX 4521F All-In-One Laser Printer
Scx 4521f open heat error - Samsung SCX 4521F All-In-One Laser Printer
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
Its probly a bad fuser but here are some steps somone else had to try before buying a new fuser if your a do it yourselfer.
1)Disconnect the power supply from the mains and the printer cable and wait for the printer to cool. Do not just turn the printer off; unplug it.
2) Open the printer. Remove the printing cartridge.
3) Locate the two Phillips screws that hold the fuser cover (the one that has high temperature and/or high voltage warnings printed on it) and remove them with a suitable tool.
4) In the middle of the fuser unit on the interior side there is a heat sensor. It has two wires, that go to a connector on the left of the interior side (with the printer open towards you). The connector sits in a holder. Pull it out of the holder, then disconnect the male from the female. Untangle the sensor's wires from the plastic wings that hold them onto the unit.
5) Now you are ready to remove the heat sensor. It is held in place by one Phillips screw similar to the two you removed from the fuser cover.
6) Having removed the screw, pull the sensor first slightly away from the fuser (to clear the plastic margin on the fuser unit) and then straight up. DO NOT apply force! it should come out very easily.
7) Now you are holding the heat sensor. You are looking at a black square piece of plastic with a hole in the middle (for the screw) out of which on one side come out the two wires ending with a connector, and on the other side, two thin plates laminated together in a soft transparent plastic material (probably silicone rubber). If you look carefully, inbetween the two metal plates sits a very tiny component - the actual semiconductor sensor.
8) On the side of the sensor that when in operation faces the hot fuser cylinder, you will find a layer of solid black residue. Now comes the tricky part: removing the residue. Careless manipulation of the sensor may result in a permanently damaged sensor. You have been warned.
9) Hold the sensor (or place it on an adequate surface, eg rubber) so that no excessive mechanical tension is applied to its active parts (the laminated plates and semiconductor). Scrape the residue off the sensor gently with an object that will not harm the transparent plastic lamination. Do not use anything sharp. The residue should come off very easily. If it doesn't, do not apply excessive force.
10) You are ready to mount the sensor back on the fuser unit. Insert it exactly as you removed it, with the active part down. The wires that go to the connector should come out the side opposite to the connector (if you took notice when you disassembled, they make a u-turn when assembled). You will not be able to mount the sensor if you insert it the other way around.
11) Secure the sensor with its Phillips screw. Do not apply excessive torque.
12) Thread the sensor's wiring through the plastic wings on the fuser body and assemble the connector.
13) Put the cover back on the fuser unit and secure it with its 2 screws.
14) Put the printing cartridge back in place.
15) Close the printer. Connect it to the mains and to the computer. Turn power on.
Posted on Oct 08, 2009
My Samsung SCX-4521F show message: Open heat error. What should I do? Thank you
you have to replace heater bulb and thermister.it is located @ your heater roller section.
Jan 26, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Open heat error,low heat error,over heat error
hello problem is your heater unit replace it is the solution or replace heater bulb,thermister.
Sep 21, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Open heat errors
Clean thermistor of dirt or Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Jul 31, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Open heat error in my printer model SCX-4521F
open heat error sounds like the fuser lamp is blown. The fuser lamp is inside the hot roller at the back which melts the toner onto the page. It is not really a user serviceable part, you would need someone qualified to repair/replace the fuser.
Apr 28, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Cru fuse error on samsung scx 4521f
i changed fuse 4521F , but : (cru fuse error) ???
Feb 12, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Low heat error
the fuser lamp is likely blown, if you turn it on and leave it for a few minutes and then feel the back access door and it is cold you will need a new fuser lamp
Nov 12, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Printer is not working despite of installing driver from web.
Oct 05, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Open Heat Error on samsung SCX-4521F
open the back cover and you find a two wire connector just near ribbon connector it is thermistor connector the printer is sensing this connector as open or not connected explore and fix.
Nov 27, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX5115 printer
I have a samsung lazerjet scx 4100printer,My printer problem is heat open error after power on,ple help me
Nov 30, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
108 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
