Question about Ricoh 2050L Laser Fax
I have a ricoh fax, 2050L. How do I change the Time?
  • melissa_bedw Oct 12, 2009
    I do not find a user tools - do you need to follow a path to get to this command?
    President:
  • 3,085 Answers
Press USER TOOLS
Posted on Oct 08, 2009
I have a Ricoh 2050L that is leaving vertical lines on copies by not transmitted faxes. How do I clean my fax or who can perform the needed service. What is a fair price in the market?
What you are saying cannot happen. When you send a fax or make a copy, you are using the same mechanism. Do you mean print outs instead of copies?
Open the doc feeder and clean the scanner glass.
Feb 10, 2010 | Ricoh 2050L Laser Fax
How do you set the time on a ricoh fax 2050l
PRESS (FUNCTION)
PRESS (6)
ENTER (2222)
ENTER(91)
ENTER(YES)
CHANGE MONTH WITH (*) OR(#) KEYS
PRESS (I>) CURSOR RIGHT KEY TO MOVE CURSOR
CHANGE DATE WITH WITH KEYPAD
CHANGE AM/PM WITH (*) OR (#)
WHEN DONE PRESS (YES) THEN (FUNCTION)
Hope this helps
Nov 20, 2009 | Ricoh 2050L Laser Fax
Need instruction manual for a Ricoh fax 2050L
Go to the Ricoh site at the following link and under "facsimile", download the Fax 2000L manual, it's virtually identical. I don't know why they don't have the Fax 2050 version, as it is slightly more recent model, but anyway, this should work for you:
http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
please rate me :)
Jun 17, 2009 | Ricoh 2050L Laser Fax
Ricoh fax 2050L displays: "Check paper size", and also shifts image or text toward bottom margin by 3 inches or so. Sometimes locks up during printout.
Thru user tools check what size is said to be in the fax and if it has the optional tray that size too. -Carl
Apr 14, 2009 | Ricoh 2050L Laser Fax
Need to change the pickup from one ring to picking up on the 5th
This should do it:
Press the {Function} {6} then enter
the access code {2} {2} {2} {2}.
Then press {6} {1} and the {Yes} key
press the 'next' (right arrow) key until it displays "set number of rings" . Press "yes" (the current setting is displayed). Press "no" to change. Enter the desired number, then press "yes" to set. Press "function" to exit.
Please rate me :)
Mar 14, 2009 | Ricoh 2050L Laser Fax
Ricoh 2050l confirmation reports
It's more complicated than it needs to be. You'll have to refer to the user manual under 'user parameters'. It's to difficult to explain here. But I can tell you that it is switch '3'......Bit '0' that needs to be changed. manual is here if you need it:
* select "Fax 2000L" from the drop down menu (it's the same as yours"
*please rate me :)
Mar 13, 2009 | Ricoh FAX2210L Plain Paper Laser
We have a RICHO fax 2050L been trying to ajust the time on the
Press "function", "6", then "2 2 2 2". Press "91" , "yes".
Now enter the new settings:
Use "*" , and "#" to toggle through months, and am/pm.
Press "yes" to lock settings.
** Note: I believe, you will have to initially set the time to Dec. 31, 1999 @ 12:59pm, and wait for it to roll over to 2000, then go back and change the time/date to 2009.
Hope this helps.
Feb 25, 2009 | Ricoh 2050L Laser Fax
Clear a Ricoh Fax 2000G Memory
    1. If your documents have already been scanned into memory:
    2. touch the [Change/Stop TX File] key
    • check that the [Stop Transmission] key is selected
    • touch the file that you want to stop, then touch the [Stop Transmission] key in the confirmation dialog box
    • touch [Exit] to return to the Fax Mode display
    1. If your documents are being transmitted:
    2. press the red [Clear/Stop] key
Dec 22, 2008 | Ricoh 2050L Laser Fax
Ricoh 2050L Laser Fax Logo
278 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
