Question about KitchenAid Food Mixers
Mixer was shipped on it's side, and arrived leaking oil, is it o.k. to operate?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 143 Answers
Yes your machine is safe to use as long as to much was not lost. the manufacturer (whirlpool) always puts more grease inside the transmission than needed. As long as you aren't getting continuous leaking this will be fine to operate. you can buy more grease if a lot was in fact lost. this can be bought at an auto supply shop. it is a thicker bearing grease.hope this helps
Thanks
Posted on Oct 11, 2009
How doI fix mixer that leaks oil out beater holes
There ate two ways to fix this problem, but first there is the matter of understanding what is leaking. The oil you see leaking is actually a food safe vegetable based gear grease. The grease separates during heavy use (years of service) or when the mixer has not been used for an extended period of time. (months or years) The recommended way to fix the problem is to do a full tear down then clean then add new grease and a new gasket, cost (By Kitchenaid at a KA service center) around $140.00 US + or -, It involves shipping and around ten days in time. The second way is kinda simple and does not cost anything. Get a towel, thick and soft to protect your finish, get your wife or husband, get an extension cord, spread the towel out on an open counter top, plug the extension cord into the outlet, turn the mixer upside down on the towel, have your significant other hold the mixer by the base while you plug the mixer cord into the extension cord, turn on the mixer no more than 2 or the second click on the speed control switch / lever, hold the mixer upside down like this while the mixer is running and keep it running for at least three (3) minutes, turn the mixer off and turn it right side up and turn on again for two minutes, then do it again two or three more times, upside down for a couple minutes then back right side up and so on and so on, after about 15 minutes stop. put everything away, you are done. What you have effectively done is re-mix the grease and it should be good for another couple of years. When it starts to leak again re-mix again. Or send it to KA for the rare and unique opportunity to spend a hundred bucks that you don't' want. hope this helps. By the way if you get some drops in your mix it will not hurt anybody. But you do not want to eat a great deal of it or you will require the use of a laxative afterwards.
Jun 18, 2014 | KitchenAid 32685 Mixer
My mixer is leaking oil. How do I fix it?
Your mixer is leaking grease not oil. It is a simple fix. First you have to open the machine and regrease it. Once you have done that try replacing the gasket. Also, this particular mixer cannot be left on its side (some people store it sideways in a cabinet or under the sink) doing so will cause the machine to leak as well.
Oct 13, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
When my 85 year old mother, who no longer does much cooking or baking, heard that my trusty KitchenAid stand mixer finally gave up the ghost after 25 years of great service, she sent me her KitchenAid...
The mixer normally has it's gearbox packed with (quite thick) grease. Over time it can heat up and become more fluid and leak out. I would guess that the amount of oil you saw would not be a problem to loose. If it were mine, I would use it and not worry. If you do feel you need to check, the grease is packed in the front of the head. You will need to remove the head, split it (you will need to remove the band and planetary) and then you can see the gears.
Jan 28, 2010 | KitchenAid K45SS Classic Stand Mixer
My Kitchenaid Artisan Mixer is leaking oil or grease
Your kitchenaid mixer is meant to leak a tiny amount of oil around the rim of the planetary gear on the front of the machine. This is just a means of lubrication. If however you are getting alot of oil coming out of the sides of the unit, the transmission gasket may be worn or broken if this is the case it will have to be replaced. part number for the gasket is 4162324. If your getting alot of oil from the center of the unit this could indicate worn or broken seals. there are 4 located inside the unit, and would need to be dismantled in order to replace. part number for all four is 3180163. If you are leaking alot of oil or grease continued use of the mixer might cause it damage. Hope this helps
Thanks
Nov 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
My stand mixer was stored on its side and leaked oil.
Called the Kitchenaid toll free number and found a local authorized repair center. Not a fixya solution, but at least a solution.
Oct 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
My kitchen aid mixer is leaking what seems to be a brown liq. maybe oil where the paddle inserts into the mixer.
This is another complaint about a Kitchenaid Standmixer, model K45SS. It leaks oil, out of the 1 year warranty period. Called the company. Got the standard line: Mixer must be run 2-3 minutes a week to avoid leaks. Nothing appears in writing about it in their manual. Oil leaks into food are dangerous. Please report these to the Consumer Products Safety Commission. After calling their service center a second time, after seeing all the complaints on this board, I informed them of my report to the CSSC. They said they would send a "return repair kit". I could send it in for repairs and if it was determined to be "defective" they would pay for the repair. The representative would not state that this is, in fact a "defect" and that I would be charged to have it inspected and repaired if it was not. Cost, anywhere from 50 to 150. I would be charged to ship it back if it wasn't defective and I decide not to have it repaired.
Read more: http://www.consumeraffairs.com/homeowners/kitchenaid_mixers.html#ixzz0TkgnvHLP
Sep 24, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchenaid Mixer leaking oil
Hi Tim. Don't try to pour anything into the side openings, these openings are for the electrical brushes. You didn't state what model you have so my help is limited. Goto www.kitchenaid.com and click on the customer care tab. Enter your mixer's model# into the search window. Look for a parts catalog for your mixer. If there is one, download it.
Your mixer uses grease to lubricate it. If it's leaking oil, the oil and old grease must be removed and replaced. Chevron FM ALC EP-2 is a "Food Grade" grease, use it to replace the old stuff. The transmission housing and Planetary assembly will have to be removed to accomplish this. It's a messy, but necessary task. Once completed, run the mixer for a few minutes each week to keep the oil suspended in the grease, this will extend the life of the new lube. Good luck!
If this solution has assisted you please rate it. ricardok45.
Mar 28, 2009 | KitchenAid Food Mixers
Model KSM90 10 speed ultra power stand mixer leaking oil at the shaft where mixer tools attach. Is there a repair kit which includes a oil seal or something like that at a reasonable price?
Hi. Your mixer needs to be serviced, have old grease and oil removed, parts cleaned, then re assembled with new grease. Remove the tapered-pin from the planetary gear, remove planetary gear, clean lubricate and re install. Chevron FM ALC EP-2 is a "Food Grade" lubricant, meaning that it's safe for human consumption if it accidentally gets into food. There are no seals, only bushings. The existing bushings will hold back the new grease. The oil has separated from the base of the grease. If you don't use your mixer very often, start it up about once a week to keep the grease properly mixed.
If you'd like more info on your mixer goto kitchenaid.com, look up your model # download the PARTS drawings. Use these drawings to re-assemble and to determine if you need any replacement parts. Be prepared to wait at least a month for your parts to arrive.
If this Solution assisted you, please rate it. ricardok45
Mar 06, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Accessories for KSM90
Hi. If you haven't already, contact Kitchenaid parts dept. They will probably have what you need. Be prepared to wait about a month for the parts to arrive, as their parts dept. has only one speed...Terminally slow. You can download the parts list and drawings for your mixer so you'll know what the parts numbers are. Ask them about shipping costs. Good luck! ricardok45.
Nov 30, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Oil spilled during shipping
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
Nov 03, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
