Question about APC Computers & Internet
APC RS 900. Intermittently the yellow battery light will come on for only a second or so, long enough to get one beep, maybe. Been on the phone with APC tech and they had me lower the sensitivity to medium. Still having problems. Worse, they techs must be outside US as they are very difficult to understand. Still under warranty.
jvpacoin
  • 91 Answers
SOURCE: Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
Posted on Aug 14, 2009
  • 773 Answers
SOURCE: APC Back UPS RS-1000 Overload LED with beeping sound after on.
this indicates you have too many things plugged into it.
Posted on Nov 20, 2009
pravinbhavsa
  • 348 Answers
SOURCE: how to use apc rs 900 without battery
No no way to use the ups without battery it will not show mains supply without battery and you cannot use it as a stabilizer you must connect battery
Posted on Mar 10, 2010
  • 84 Answers
SOURCE: My APC RS 900 UPS is making a beeping noise and
Without knowing which light is flashing I can only guess. From my experience and assuming it is the battery light that is lit and NOT the overload light, it can be one of two things, one is your battery is near the end of its life and needs to be replaced, and the other is that your battery is improperly connected.
To confirm if your battery needs to be replaced or not, you can run a self test. Ensure that the battery has had time to fully charge (and that it is definitely correctly connected), and then turn off the UPS, and turn it back on. It will automatically run a self test.
if the light stays lit, you need to order new batteries. One source is here: http://www.refurbups.com/APC-Back-UPS-RS-900-BR900-Replacement-Batteries
If it IS the overload light that is lit, you simply have too much equipment attached to the UPS, more than the inverter can handle. Try removing some equipment until it turns off.
Posted on Mar 31, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: I just replace the battery
Sorry to read about your problem, I hope this helps you out.
let it charge 24 hours, and see if it works
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 22, 2010
Apc beeping twice every 2 seconds
The battery inside the APC is "weak", and the "beep" is telling you to replace the battery inside the APC, or, maybe cheaper, to buy a new APC.
Feb 03, 2014 | APC BACKUPS ES BE550G 8Outlet 550VA 330W...
I just replace the battery in my APC RS 900 unit because the red indicating light was telling me to do so. I installed the new battery and the red indicating light is still telling me to replace the...
Dec 22, 2010 | APC Back-UPS RS 800VA UPS System
Rs 900 back up is beeping with the on battery, overload, and replace battery lights blinking
just check that you are not overloading the ups or make sure that the ups output is not connected to the input of the ups in most of such cases almost all light indicators start blinking
Dec 04, 2010 | APC Back-UPS XS900 (BX900) UPS System
My APC RS 900 UPS is making a beeping noise and the red light on the front is blinking. It seems to be working, but what is it trying to tell me?
Mar 18, 2010 | APC Computers & Internet
How to use apc rs 900 without battery
Mar 09, 2010 | APC Back-UPSĀ® XS 900 (BX900R) UPS System
After a power outage my apc has this clicking sound. every 4 seconds or so it sounds like it clicks and then a slightly different click 4 seconds later. However, when everything is powered up it doesn't...
I found this on the APC website;
Question: What would cause a Back-UPS Pro, a Back-UPS Pro USB, a Back-UPS RS, a Back-UPS CS, a Back-UPS LS, or A Back-UPS XS to beep once every 5 seconds with no output power?
Answer: One beep every 5 seconds is an indication that the UPS has entered what is called "Low Voltage Sleepmode".
The Back-UPS product has transferred to battery power due to a low voltage condition at the wall. The Back-UPS has remained Onbattery until its runtime was totally exhausted, however, there was still enough voltage present at the wall to trickle charge the battery.
This is considered to be a normal operating state. When the voltage returns to normal the Back-UPS will wake up and restore power to the battery outlets.
Nov 02, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
Jun 11, 2009 | APC (br800) UPS System
Beeping error
on the heatsink thats in front the fans theres six fet irfb23n20d mine had the outer two towards the fan short circuited.replaced them and all is well now.
Oct 24, 2008 | APC Back-UPS RS Battery Backup (apw...
Computers & Internet Logo
134 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
