Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Door panels for frigidaire dishwashers
Is it possible to get replacement door panels for the frigidaire fdb1050rec?
  • Anonymous May 09, 2008
    I need a replacement door for Whirlpool GU2400XTPQ3 dishwasher. I want to change it from white to stainless steel.
  • Anonymous Oct 06, 2008
    I have a frididaire dishwasher and want to switch from a bisque to a white door
    President:
  • Frigidaire Master
  • 2,651 Answers
Sure its possible,stainless steel door 154538305 approx $100
Posted on Feb 23, 2008
How do i remove front door cover?
Good Morning Friend,
I understand you are replacing the soap dispenser in your Frigidaire dishwasher, model# FDB1050REC, and want to know how to access the screws to remove front panel of the door. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals for this repair. I suggest contacting your local authorized technician for further assistance. I hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire fdb1050rec 154427301 Have had this
Good Morning Kate, thank you for your inquiry!
Often when a dishwasher leaks, it is because the unit could possibly be unlevel. If not, water can be leaking over the front lower baffle in the door. Try looking along the cabinet and see if the unit is even with the cabinet. Measure the correct amount of detergent as found in the Owner's Guide. It is recommended to use one teaspoon for every three grains of harness. If regular dishwasher detergent (for sink use) is used in a dishwasher it can also cause excessive sudsing. Lastly, the dishwasher could possibly have a loose water vale or a crack in the tub. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Sep 05, 2013 | Frigidaire PLD4555RFC Dishwasher
Frigdaire 900 series - Door has become heavy as though there is water in it. What's wrong and how do we fix it.
Hello - Sounds like the hinges may need to be adjusted or if they are too damaged, possibly replace.
Nov 02, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Front stainless panel is rusting. can it be replaced
Hello pam boutin - Yes, the panel can be replaced. If your model number is FDB1050REC, the part number is 154538305 (door, stainless). MSRP $ 136.66 and you may purchase part directly from the manufacturer or through a part distributor in your area (part numbers may be different).
Oct 13, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Is it possible to change door panel for
YES! go to www.applianceart.com they have hundreds of options (including stainless) for your dishwasher.
Jan 24, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Feb 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Replacement Door Panel for GE Profile Dishwasher
Are you trying to replace the microwave door or the GE dishwasher. Either way, www.applianceart.com (under the stainless steel section) has this roll of stainless material that you apply to your appliances. I saw it on the "Today Show." Its basically faux stainless. We put it on our refrigerator and it looks and even feels like real stainless steel. Its really cool. I think its called stainless foil or something like that. Also if you're looking for a stainless panel for your dishwasher they sell actual stianless panels there too.
Nov 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
3,254 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
