Question about Garden
Code 7RR1.7 service code 7RR1.7 on hour meter on a scag mower
  • 472 Answers
Ive never seen one do that i cked it out and found out that your meter is bad i called scag for you thay said the meter is bad hope this helps
Posted on Oct 15, 2009
What is the rectifier for the scag zero turn riding mower
You did not post what model this is on. However this is most likely the voltage regulator on the engine. The Scag brand has numerous issues with this item and electrical problems in general. I would contact SCAG about it.
Oct 21, 2016 | Garden
Scag turf tiger 61"
Check switch with ohm meter.
May 21, 2014 | Garden
Scag mower
Most have a bolt on end the crankshaft.
Oct 25, 2013 | Garden
Scag mower
If equipt, check the low oil switch circuit. Might be a failing switch.
Sep 24, 2013 | Scag STT61V-791DFI-SS Gas Turf Tiger...
How to reset hour meter on encore mower
As far as i know there is no re set for the service minder/hour meter, it will be a replacement.
Jun 09, 2012 | Garden
Will my 16 hp Briggs from Craftman rider fit Scag walkbehind?
you would need to see what size crank shaft the scag had on it most motors used the same bolt down the same and you could always drill new holes so the shaft size to fit the pulley the scag had i put a 25hp briggs on my riding 61'' scag it had a kohler bolted right on the wiring was different
Apr 19, 2012 | Craftsman Garden
My scag mower won't run and spark plugs are not firing
unplug the harness and crank it over see if there is spark then is yes check the safety switches if not check the coils
Apr 12, 2012 | Briggs & Stratton Garden
I just got a riding mower (D100) and it has 7 hours on it but the service notification just came on....i checked and it has oil. The belt came off while mowing last weekend but I put it back on and it...
Here are the is the process that the notification will appear:
How Does Your Hour Meter Function? Model Year
Model Number and Product Identification Number Groups. Is the tractor equipped with an hour meter? Does it accumulate hours with the key switch left "ON", but not running? How long does the service reminder (SVC) display before and after service intervals? Does the Hour meter stay lit or display hours when the key is in the" OFF" position? Does the hour meter only count hours when the engine is running? 2008 - 2011 D100 D110 D120 D130 D140 D150 D160 D170 LA105 LA115 LA125 LA135 LA145 LA155 LA165 LA175 Yes No half hour No Yes
The notification should last for 30 mins before and 30 minutes after the service interval before it stops flashing. It is not resetable.
It does make one wonder why it started flashing at 7 hours vs 25 or 50 hours though. Possibly a battery was replaced and the running trime vs the service time intervals are not syncronized.
The service (SVC) arrow indicators will last for 1 hour. It will display ½ hour before the specified service interval and one 1/2 hour after the specified service interval.
The left "SVC" arrow will occur at 25 hour intervals (25, 50, 75, 100 etc.).
A "SVC" arrow pointing to the left will indicate that a general lubrication interval has been reached.
The right "SVC" arrow will occur at 50 hour intervals (50, 100, 150, etc.).
A "SVC" arrow pointing to the right will indicate that service is necessary for the mower and the engine.
Thanks for choosing FixYa,
Kelly
Thanks
Jul 16, 2011 | John Deere Garden
Trouble code ch6 oil on hour meter
Sounds like your oil low switch is either bad or maybe wire was knocked off when changed oil.
May 11, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
141 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
