Question about Cycling
Maestro suspention makes a cracking noise
Giant maestro suspention makes a cracking noise when in hard use
    Problem Solver:
  • 5 Answers
Its broken replace immediately,
I should know I'm a giat techncian
Posted on Oct 20, 2009
Suspention noise
This model often develops a noise from worn rear sway bar bracket bushings. They are inexpensive, so I would replace them and see if that was the problem.
Jul 12, 2013 | 1995 Toyota Camry
Suspention noise in lancer
check all rubber bits for loose or broken include top and bottom of shockys. stabiliser bar and rubber block at top of strut etc inside engine compartment look for cracks and tears
Jan 24, 2013 | Mitsubishi Cars & Trucks
Rear end noise when turning truck is lifted. An it only does it when the wheels r turned. Where do I start to fix the problem
Start at the front wheel bearings its likely the sourse of the noise . If you modifited the suspention and it olny happens when the wheels are turning then its a wheel bearing . A nd the sound will tranfer all over the vehicle and make it hard to pin point sound travals . Look at your wheel bearings it can make a scarry noise but if you don't see fulid leaking all over the place and it shifts OK and runs OK then this is likely the problem
Sep 17, 2011 | 1998 Chevrolet C1500
No response freez making funny noise
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Is it an external drive?
If it is, open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
Lastly, if its not an external drive, the same applies because, its still all about hard drive.
I wish you all the best.
Jan 08, 2010 | LaCie F.A. Porsche (301177) Hard Drive
My hard drive doesn't start. I was on vacation for a month, before leaving I unplugged it and now I returned, plugged, but it makes noises, but no lights or info...
is it an external hard drive? If its not an external hard drive, the same solution still applies because its still about hard disk.
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
Jan 07, 2010 | Computers & Internet
Little Giant stopped working; makes hum noise but wont push wate
Can you take it out of where it is and clean it with vinegar? There may be calcium built up in it. I have one also on my aquarium and when I turn it off sometimes it won't start back up, just humms.. That tells me it's time to clean it.
Jun 07, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
My 2003 Landrover will not go up or down.
you have a leaking front air spring and your abs is activating
Mar 31, 2009 | 2003 Land Rover Range Rover
Cycling Logo
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
