Question about Delfield 032-F2FH ColdPro Solid Door Reach in Freezer 2 Section
Fridge not getting cold - cleaned coils, etc. no change. Suggestions?
How does the fridge compartment get cold? Is it a thermostat or condenser problem?
The self defrosting feature of your unit has a failed component. Possible defrost heater, defrost thermostat, or timer. The defrost timer may be part of the main circuit board of the unit.
Jul 27, 2014 | KitchenAid Refrigerators
Refrigerator doesnt seem to cool enough, things are freezing in the bottom shelves of fridge but nothing else is getting very cold
Take a hammer and tap lightly on the coils every half inch. It will take a few minutes to do this to break up the crud in the coils. The crud may plug up a dryer, but it was not working anyway...
Apr 07, 2014 | LG LSC27921ST Stainless Steel Side by Side...
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Fridge not cold
i have had this same problem. Pull the back cover in the freezer off. If there is a bunch of ice on the coil change to heating element.
Jul 05, 2009 | Maytag MSD2454G Side by Side Refrigerator
Refrigerator not cold . Motor keeps clicking on
Sounds like it is cycling on overload. Condenser coils (may be on back, or under bottom of fridge) may need cleaning. If coils are under bottom, it could be the condenser fan not working, causing it (compressor) to overload. Possibly compressor start relay bad. Worse case, compressor may be bad. If you don't know much about electrical stuff (compressor, relay, etc...) you should have a repair tech check it for you. If coils are dirty, clean them with a vac and coil brush (gently). You can get coil brushes at most hardware stores (Lowes, Home Dep, Ace, etc...) Hope this helps.
RH
Jun 25, 2009 | Amana Refrigerators
Whirlpool side by side - refrigerator not staying cold
How old is it? have you ever cleaned the coils under neath where the dust gathers?
I've seen people that never cleaned the coils underneath and behind the plastic grill at the bottom front of the fridge that had a warm fridge and the after they used a refrigerator brush down below were okay the next day!They had 2 inches of solid dust under there blocking the air that is supposed to be passing over the coils to cool the system!! Get out the book and read the directions how to do this procedure that I'm telling you about first before you call service! If it's not caked with dust and obscuring
the site of the coils, then you need service instead!
Bless You
Sep 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Fridge too cold
First, clean it the unit out and fully defrost.  Clean the condenser coils.  Don't pack in so much food, don't open the door too frequently.  Never block any air channels. Never leave uncapped liquids in the fridge or freezer.  Set the fridge at about 40 degrees...use an outdoor thermometer.  Freezer at about 0-5F.
Aug 21, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Delfield 032-F2FH ColdPro Solid Door Reach in Freezer 2 Section Logo
41 people viewed this question
Top Delfield Refrigerators Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Are you a Delfield Refrigerator Expert? Answer questions, earn points and help others
