Question about Canon EOS Elan 7ne 35mm SLR Camera
Canon 400d err99 message when trying to take a picture. how do I resolve problem?
  • 1,029 Answers
Error 99 also refers to communication problems between lens and camera, so worth cleaning the contacts...you can't lose anything in doing so.
1. Take your battery out and reinsert it - this will clear it.
2. Clean your lens contacts carefully with a plastic pencil eraser. Sometimes corroded contacts can cause errors like this.
3. Try the camera with different lenses - if it is occuring with several lenses, it may point more strongly to a camera fault.
4. Make sure you have the latest firmware installed.
Posted on Oct 08, 2009
My 400D won't turn on
Did you overtighten the tripod screw?
Aug 16, 2009 | Canon EOS 400D Digital Camera
Error 99! Wont' take picture, the message states
Go to the www.canon.com website and find out what Error 99 means. ted10
Apr 18, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I have a canon EOS 400D and when i turn it on it works fine but when i start to use the flash it doesn't flash i get on the screen ERROR 99 ! what do i do ?
ERR99 means the camera is not communicating with the lens - probably just dirty contacts.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 14, 2009 | Canon Digital Rebel / EOS-300D Digital...
Keep getting ERR99 when i take my first shot after switching on.
Jan 23, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
I have error 99 in my camera canon 400d
Ifd the camera is only 3 months old - return it for replacement
Sep 01, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon eos 400d
Contact Canon - some makes of lens which are not Canon are not electronically compatible for various reasons, and can actually damage the camera. So, get using the phone and check if it is compatible before doing anything else - but personally, I would not use the lens until I find out
Jul 02, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Busy message on computer and camera
Try resetting the camera to factory defaults - Here's how:
  • Firstly press the 'menu' button, then the up button above the 'OK' as many times as needed, until you see the top folders are highlighted.
  • Press the right button near the 'OK' until you see the last folder highlighted. You will know this is highlighted when you see the first menu option that says 'Language'. The 3rd one down from that says 'Clear Settings'.
  • Press the down button under the 'OK' until 'Clear Settings' is highlighted, then press the 'OK' button.
  • Scroll up to your choice and press 'OK' to reset your Canon 400D back to default factory settings.
Hope this helps
Jun 27, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Error code 99 canon E0S 450D
Try this:
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Jun 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
CF error
My canon xti had the same reading cf card error 99.
Since my camera is out of warranty. I had to find a way to fix it. After reading all possible solutions in this site, I looked at the pins (that used to connect to the CF card) and found out that one pin in the middle bent. That caused the problem. I used the tiny screw driver to bend that pin back to the original position. Inserted the card back and it worked. I felt so happy!!!! (Please make sure to have the battery removed while fixing...to be saved.)
Dec 28, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
My Canon is displaying - Err 99 what should I do?
Just found this info which should help diagnose the err 99 issues (info direct from Canon apparently)
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 10, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Canon EOS Elan 7ne 35mm SLR Camera Logo
217 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
