Question about Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 green screen - Sony KDSR50XBR1 50" Projection HDTV
  • 3 Answers
There is a problem with a particular part, not sure which one, but SONY is aware of this problem and will have it replaced free of charge. Contact SONY service.
Posted on Nov 10, 2009
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Tip
Green and/or yellow tint in picture
This si usually caused by a bad optical block. Sony has extended the warranty on the optical block, including parts and labor through December 2008. You can find more information here:
http://ciscdb.sel.sony.com/US/perl/news-item.pl?mdl=KDSR50XBR1&news_id=185
on Nov 13, 2008 | Sony KDSR50XBR1 50" Projection HDTV
There is video and sound in all imputs but the picture is totally green, any suggestion? Thanks.
If the Picture has Video and is all green or yellowish green, you probably need a Optical Block. Sony has extended the Warranty on these Optical Blocks but you need to contact them quickly. It is a very expensive part and they should take care of all the Parts and Labor involved.
You can contact Sony's Customer Service at 1800-222-SONY.
I hope this helps,
Skyassoc
Oct 29, 2009 | Sony KDSR50XBR1 50" Projection HDTV
I have a sony kdsr50xbr1 screen turns off after 15 min, there is still sound but the screen is essentially blank. Sometimes there are bars on the side of the screen for a second. The the status light...
Hi!
Please try disconnecting all the cables from the TV then reconnecting them back after a few minutes. You may also try connecting the power cord from the TV directly to a functional wall outlet. If the issue persists then the projection lamp needs to be replaced.
Aug 27, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Sony lcd projection screen shuts down and green standby light flashes 53 times and then the tv reboots and evrything is fine. what could this be the model # is KDSR50XBR1
The Lamps have been known to cause odd shut off and on issues. Particularly if the Lamp has 3000 hrs or more. The average life of a Lamp is 3000hrs.
Hope this helps
Skyassoc
Jun 26, 2009 | Televison & Video
Green Tint
bad optical block call sony they have a recall
Jun 01, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Green Tint
Green tint is caused by a burned or distroyed filter in the optics. It must be removed and sent out to be
rebuilt or replaced.
Mar 21, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Yellow spot on the screen
You have a bad optical block. Sony has extended the warranty on your TV so the block will be replaced for free. Go here for more information:
http://ciscdb.sel.sony.com/perl/news-item.pl?news_id=185&mdl=KDSR50XBR1
Be sure to rate this solution! Thanks!
Nov 11, 2008 | Televison & Video
Color convergance
The green hue (I had it too) is a result of the optical block failing.
Sony has extended their warranty (regardless of the purchase date). see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDSR60XBR1&news_id=185
Apr 24, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
218 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
