Question about Sharp AL-1000 Laser Printer
How can i remove H 4
My Photocopy Al- 1000 sharp is showing H&4 and i want it to stop
    President:
  • Sharp Master
  • 1,447 Answers
Press c> photo>C>photo press 14 press start/Print key
machine ok
Posted on Jan 02, 2010
How do i reset a sharp al-1553 photocopy
Try unplugging it for 20 minutes. If that doesn't work, go online type "sharp al1553 user manual" and it will show sites to get manual. Use the trouble shooting section.
Apr 28, 2016 | Sharp Office Equipment & Supplies
Sharp AL-1000 error E7
E7 is CCD drive circuit trouble. Refer to the manual
obtainable from mauritron
Feb 21, 2011 | Sharp AL-1000 Copier
MY SHARP AL-1000 PRINTER IS PRINTNG VERY FEINT
Could be either one. Probably toner.
Apr 06, 2010 | Sharp AL-1000 Copier
Repairs of sharp AL 1000
Sounds like the scanner is locked. Look under the scanner where the paper comes out, there is a clear wheel, turn it all the way one way or the other and that will unlock the scanner.
Oct 21, 2009 | Sharp AL-1000 Copier
PLEASE HELP ME
you have to reset your drum counter in the maint mode. do you knoe how to get in the maint mode?
Dec 10, 2008 | Sharp AL-1000 Copier
Sharp AL-1340 Scanner hangs up, grinding sound, with E-7 code
The scanner rails will dry out. Try a drop of oil on the rod the scanner travels on. There are two bushings that slide along the rod/rail. Good luck.
Nov 10, 2008 | Sharp AL-1000 Copier
H 4 FLASHING, MANUAL LOST, AL-1220 Sharp Photocopier
Try to press #, Interrupt, C, Interrupt in that order and enter 14 then press copy key.
Oct 20, 2008 | Sharp AL-1000 Laser Printer
Error on sharp copier
That has to do with the laser unit and/or the white shading plate.
First remove the platen glass and clean the white strip on the bottom side. BE CAREFUL FOR THE GRAY OR BLACK LINE ON THE STRIPE IF YOU WIPE IT WITH A SOLVENT AND REMOVE THE LINE YOU ARE DONE.
If the unit is making a whining noise it is probably the laser unit polygon motor.
If the scanner mirror system is hanging or not returning to home position check to see that the scanner lock on the underside of the scanner where the paper comes out is unlocked.
May 19, 2008 | Sharp AL-1000 Copier
Sharp al 1000 shows E and 7 and hangs off
if a number and alphabeth appears alternately The copier will not function. Turn the power
switch off, remove the power cord from the
outlet, contact any authorized service
representative for overall service maintainance
May 18, 2008 | Sharp AL-1000 Laser Printer
Sharp AL-1000 Laser Printer Logo
103 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
