Question about Jet Garden
Stihl 023 chainsaw. A friend borrowed & changed mixture settings. I thought all the way in & 1 1/2 turns out for air & petrol. Pretty sure these two screws are side by side, unsure which is which but same setting? Idle screw unsure how to set? Used 40:1 mixture? Changed spark plug. Possible needs carbie kit as has had wrong fuel thru & been flooded heaps. Please help as this belongs to brother in law & need to get going asap. Cheers, Carolyn
  • carolyn_sear Oct 08, 2009
    Thank you SOOOOOOooooo much! Didn't want to get in the "poo" with brother in law! Cheers, Carolyn
  • Jet Master
  • 15,557 Answers
What is the petrol to oil ratio for this engine
http://www.csgnetwork.com/oilfuelcalc.html
In the Mix
All STIHL gasoline-powered equipment uses a 50:1 gasoline/oil mixture. The chart below can help you figure out the correct measurements to use. For high-performance fuel that requires no mixing, choose STIHL MotoMix® premixed fuel.
Jul 20, 2015 | Garden
Adjustment knob settings on stihl ms 362
Turn the High mixture screw out 1 1/4 turns from fully seated position.
Turn the Low muxture screw out 1 1/2 turns from fully seated position.
Make sure that your fuel mix is 50:1 and that your Air Cleaner and Spark plug are clean.
If your Stihl is still not running correctly, clean your exhaust screen and muffler thoroughly as this can cause performance issues if not clean.
Sep 08, 2014 | Garden
What kind of oil and gas mixture to I use for my stihl kombi?
When you buy the 5L of unleaded Petrol (the same as a car uses), mix with the recommended amount of 2 stroke Stihl oil as marked on the container that the Stihl 2 stroke oil comes in.
Do not use any make of oil other than Stihl or Husqvarna 2 Stroke. I have come across so many people who have tried to cut corners by buying cheaper oil. If you are asking the question you are obviously not going to use the saw to cut down hundreds of trees so for a few pence/cents more for each fill, give the saw the best chance to last.
I always mix the can with 2 stroke oil as soon as I arrive home from the petrol station and MARK the can very obviously as 2 stroke. If you don't use the mixture within 1 month, it is a good idea to use it up in your garden mower. That is as long as the mower does not have a catalytic converter. It will work fine on the very weak oil mixture that modern saws require.
May 18, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
How much to tighten spark plug on stihl chain saw model 028?
General rule is to tighten it by hand, then turn it with a ratchet another 1/8 to 1/4 turn.
May 06, 2014 | Stihl Chain Saws, 017, 019, 021, 023 & 025
What fuel does stihl MS 192 T take, 2 or 4 stroke?
these small engines take 2 stroke oil/gas mixture, usually a 50 : 1 ratio, a little heaver on the oil is better than too light. the oil in the gas lubes the internal parts of the engine. if straight gas is introduced into gas tank just remove & replace with 2 stroke mixture. if engine has not been operated with straight gas, no harm will be done.
Apr 26, 2014 | Garden
Stihl MS250 overheats and burns out engine.
the carb fuel augments mite be set to lean or gas oil mixture not mixed rite
Apr 11, 2014 | Stihl 021 023 025 Ms210 Ms230 Ms250...
What is the petrol/oil mixture ratio for a STIHL FS 36 R Grass Strimmer?
Hi, 50 to 1 with stihl oil or 25 to 1 with any other brand 2 cycle oil. Hope this helps, regards Phil.
May 30, 2011 | Garden
Husqvarna 55 1997 7351593 whatis the oil to gas mixture
The mixture is 40:1 that is 40 parts petrol to 1 part 2 stroke oil. Use good quality 2 stroke oil, e.g. Husqvarna or Stihl, rather than the cheap stuff you get at car service stations. This will prolong the life of your chainsaw.
Apr 24, 2011 | Husqvarna Garden
STIHL CHAINSAW MIXTURE SETTINGS
one turn high and low 66 has compesator carby willrun rich up high but will lean under load
Aug 31, 2008 | Garden
Garden Logo
79 people viewed this question
Top Jet Garden Experts
Dennis Key
Dennis Key
john h
Are you a Jet Garden Expert? Answer questions, earn points and help others
