Question about Samsung HT-X50 System
I have a Samsung HT-X50 Surround Sound, a LG 50" Plasma 50PC5D TV, and DISH Network Satellite.
I can play a DVD and the Samsung system works GREAT! BUT... I can not get the Regualr Dish Prgramming to work thru the Samsung system. I have the new HDMI cable installed, is there something I am missing? Is there a way i need to hook up the dish recevier thru the samsung?
  • 3 more comments
  • ChesterBunny Dec 27, 2007
    I came to find out that thru the HDMI cable, only DVD'S will play. To get the surround sound thru my DIsh programming, I had to use the old red and white RCA cables from the AUDIO OUT jacks on the back of my LG plasma TV to the IN outlet of the HT-X50. It works great now, but I need two remotes or two seperate buttons on the same remote JUST to adjust the volume. I have the HT-X50 remote programmed to my LG TV, but the volumes do not act in synch. Also, HT-X50 echos. It is slower than my LG TV. I know how to slow down the Samsung set, the HT-X50 manual explanis that, but I did not see any method to speed it up. :(
  • jfngrs33 Jan 18, 2008
    I have the same problem, TV air which I use for HD football etc, and my direct tv which is older and does not have HD, both are out of sync and I want it fixed for the super bowl. I can't figure it out, I also have the DVD problem where I watched most of a movie and then the video goes out and i just have sound, if i stop it an start again it came back on but goes out again, after all the wiring I hate to take it back, I need help too.
  • makenziele Jan 24, 2008
    i've tried the RCA cable solution from LCD TV to Home Theatre but it's not working for me.
    help!
  • peepshowrom Apr 20, 2009
    I recently moved and have been setting up my Hi Def LCD TV with the 5.1 Samsung surround sound. I have Bright House cable and the sound won't go through the system, however, when I play a DVD the sound goes through the Samsung player and it sounds amazing! What am I doing wrong??? Everything else seems to be working just fine it's just the sound through the cable.
  • Anonymous Mar 30, 2014
    receive message fan not working on Samsung system
How can I get surround sound to work on my tv. When I pull up my menu and go to audio the SRS Trusurround XT is not in bold so I cant figure how to connect it so I can have the surround sound coming from the system and not from the tv. Please help.
Posted on Nov 18, 2008
    Problem Solver:
  • 4 Answers
You need an Optical Audio Cable. Hook one end to the HD Cable Box and the other to your Surround Sound System. If you dont have an Optical Cable to your Cable Box, then try using the usual audio cables. But, I have HD and it worked with the Optical Audio Cable.
Posted on Dec 26, 2007
Our surround sound will not work on my tv either the SRS Trusurround XT is the same way not in bold. Getting very frustrated it will work on Mp3 and Wii but not with my cable tv. HELP!
Posted on Jan 31, 2010
My HT-X50 system has a volume problem. The volume is very low, you have to put the speaker to your ear to hear it.
Posted on Aug 21, 2009
Samsung HT-X50. I just installed a new 50" plasma TV and cabled the digital out to the Samsung HT-X50 digital in via an optical cable. The TV audio is now heard through the HT-X50 speakers but only...
Look into the TV's audio controls. If it was my setup, I'd NOT send audio through the TV to the hifi, nor video through the hifi to the TV. Additional hops and interconnects cause problems even though they're theoretically transparent.
Jan 23, 2011 | Samsung HT-X50 System
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
No sound out of 4 of 5 speakers when using tv only.
switch around rca cords and verify its not a bad wire(s),Check and see in the TV menu audio settings are correct/ balances R/L etc. audio outputs are on,Try different theater amp if you have an extra.
Jan 26, 2009 | Samsung HT-X50 System
I cant get my samsung home cinema system to play through my t.v
I bought the optical audio cable ($15 WalMart) and use the Digital In on the DVD player to play the sound through the surround system and turned the TV speakers off. Works great! The optial audio has square ends and looks transparent with just one round shaped cable that goes from the TV to the back of the DVD player.
Jan 01, 2009 | Samsung HT-X40 System
CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Apr 04, 2008 | Samsung HT-Q100 System
Samsung surround sound wont connect up properly to samasung plasma tv
i have a plasma samsung 42 inch and i dont know how to connect my jacks red,white, yellow from the dvd to the plasma and what channel should the plasma be on to see the dvd ???? thanks anthony
Mar 28, 2008 | Samsung HT-Q100 System
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Samsung HT-X50 System Logo
2,357 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
