Question about Panasonic Workio DP-2310 All-In-One Laser Printer
Panasonic 2310 - Printer is leaving a black streak on the paper and the shop says its the developer unit. Can I buy a developer unit and install it?
  • 8 Answers
SOURCE: what causes the toner to
YOUR FACE OR YOUR BAD BREATH!!!!!
Posted on Jan 24, 2009
  • 30 Answers
SOURCE: Black streaks through pages
There can be some reasons:
1. The Fuser is too cold, so toner was not fixed
2. Image Transfer Belt is defect or dirty
Greetings from Germany
Posted on Mar 20, 2009
SOURCE: STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Posted on Apr 17, 2009
NitrusInc
  • 326 Answers
SOURCE: Black streaks on paper
Could you describe these marks for us please.
Are they small specks or blotches? Bad Toner Cartridge
Are they lines:
Horizontal - Transfer Roller or Charge Roller
Vertical - Bad Toner OR Bad Fuser.
Note: A bad toner cartridge can render all of the parts listed here useless. Check for build up or lines on the cartridge reflective drum. Avoid light, as with film.
If they are a mix of both, the device needs to be cleaned with a can of compressed air. You must remove the cartridge, paper tray(s, and fuser to create clear path.
Posted on Apr 28, 2009
jennifer953
  • 23 Answers
SOURCE: BIG BLACK STREAK ON PAPER
If you're experiencing horizontal streaks, and already tried changing cartridges but that don't help, look in the bottom of the paper tray. If that small metal ground terminal gets ditry or bent, that could be the cause.
Posted on Sep 10, 2009
Canon c2880 streak across width of 8 1/2 X 14 paper when printed
THE PAPER SELECT ARE NOT COMPATABLE, SELECT LGL IS EQUAL TO 8.5/14 FLSC IS EQUAL TO 8.5 /13. TRY TO SELECT BLACK COLOR OR CLEAN YOUR DEVELOPING UNIT.
Feb 06, 2014 | Canon imageCLASS D880 All-In-One Laser...
Streaks on paper
make sure the glass is completely clean also the regilla of exposure
tend to be waste paper or corrector.
Dec 06, 2013 | Panasonic Workio DP-3030 Printer
It is leaving heavy blue streaks on everything printed
Hey, blue streaks could be a few different things. The first thing I would check is the image unit. Try swapping out the cyan(blue) image unit with another color, such as magenta. If the streaks change from cyan(blue) to magenta in color then you know the image unit is bad and must be replaced (part # 108R00581). If it is not the image unit then it most likely is the developer. The developer takes about 40 minutes to install and really should be done by a service technician.
Here is a video that shows you how to remove the image unit and where you can purchase one.. Just go to 57 seconds in the video. Hope this helps, good luck!
May 17, 2011 | Xerox Phaser 7750GX Laser Printer
Ricoh Aficio 3800C: How do you clean the Development Unit Hello, I have a Ricoh Aficio 3800C. I noticed that there are faint Cyan streaks when I print. I opened up the printer/copier unit and looked at...
I believe what you are referring to is the drum inside the toner cartridge. The drums are usually very strong colors, blue or green and if it is streaking then the drum cleaning blade has failed on the inside and you need to replace the cartridge.
Feb 14, 2011 | Ricoh Aficio AP3800C Laser Printer
I have Panasonic Workio DP-2310 copier and there were multiple lines the length of the copy .I cleaned entire copy and drum area and installed new toner cartridge now the copies are coming out blank , no...
check you drum charge connection between drum unit and developer unit, two metal strips at back that contact when the two unit are closed. none or bad connection means no charge and then blank copies
Feb 01, 2010 | Panasonic Workio DP-2310 All-In-One Laser...
CLX-3160FN has vertical streaks where it does not print
If your printer looks like this:
Then you need to clean the developer blades. In the image above it is the black blade that need to be cleaned. If there are streaking on any other color, then then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade.Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Aug 10, 2009 | Samsung CLX 3160fn All-In-One Printer
Most leasing companies will not provide financing unless you have a maintenance agreement by an authorized servicing agent. These parts should be covered under that agreement. If I can help, contact me at www.Xippa.net.
Apr 10, 2009 | Panasonic Workio DP-2330 Printer
Brother MFC 4350: Black Streaks on Page
Check your office supply store for printer cleaning paper. It is a heavier weight paper that is sticky on both sides. Run it through several tines to get paper dust off the rollers and paper path.
Aug 09, 2017 | Brother MFC 4350 All-In-One Laser Printer
2 faded areas on print out
Feb 20, 2009 | Samsung CLP 300 Laser Printer
What causes the toner to leave color streaks on the paper? It's leaving red streaks and I've replaced the magenta & black developers....but could it be the PCU causing the problem?
The developers almost never streak. I would be looking at your PCUs. Developers have a tendency to leave voids and dust the paper. PCUs tend to streak as the cleaning blade and charge roller wears out.
Jan 24, 2009 | Ricoh Aficio CL7200 Laser Printer
Panasonic Workio DP-2310 All-In-One Laser Printer Logo
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
