Your problem sounds like drum rollers have flat spots on them or
in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove
the front of the dryer. This will expose the drum and belt, remove
the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them
replace them.
If they don't then they probably only need lubrication. Lubricate
the shaft of the roller with a good grade of machine oil such as 3
in One oil. Reassemble the dryer, plug back in. This should solve
you noise problem.
Good Luck,
I hope this helps
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.The noise seen on the front panle is due to vibration from the motor drive
