Question about Amana SXD524VW Side by Side Refrigerator
The freezer turned as cold as possible stays around 5 - 10 degrees above zero
    President:
  • 1,304 Answers
Check to ensure you have good fan circulation in the freezer and that coils an not covered in frost
Posted on Oct 08, 2009
Testimonial: "Thank you"
Model no. pfs23kshss ge profile refridgerator left door does not match up flush on the outside with the right door. we can feel the cold air escapifridge temp was 62 degrees and freezer at 10 degrees
Gotta stop the air loss by fixing the hinges and/or replacing the door gasket. Freezer should be around zero degrees and fridge around 40 or less.
Jun 28, 2015 | GE Refrigerators
How cold should the freezer get?
I am assuming you are referring to Fahrenheit.. 16 is a little warm for a freezer. They usually stay around zero to 10 degrees above or below.
Sep 14, 2014 | Samsung Refrigerators
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
I have a ge profile refrigerator that is about a year old in st thomas in the usvi. we had the fan and sensor replace but the freezer keeps going to down to -20 below and the then comes up but never to...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Aug 22, 2011 | GE Profile PSW26P Stainless Steel Side by...
My Sub Zero 550 model seems like it is running all the time. It is too cold in the refrigerator compartment,and the condenser fan runs constantly. Adjusting down the temp control has no effect. Freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 15, 2010 | Sub-Zero 650 / O Bottom Freezer...
Freezer works but fridge doesn't stay cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
My freezer wont stop running
either the cold control thermostat is defective or the rtc overload contactor has welded itself together and cant open and close the power contacts to the unit,un plug the cold control and see if the unit stops then
Feb 27, 2010 | Nor-Lake Freezers
The refrigerator is not staying cold
Check it's cealing of the door. Depends if it's cooling and then not staying cold, means door is not cealed or frequency of opening too much. More possibility is gas leakage.
Mar 04, 2009 | Frigidaire FRS26ZSG
Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Oct 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge side not cooling, Freezer side is....
(After trying FixYa and paying for the premium service -- during which error codes were not even discussed) I called a service tech. Turns out it was the fan above the fridge side (which explains why the freezer was still working fine) that was "humming" but not always spinning. A quck swap of the fan and we were back in business.
FYI -- The SubZero tech said it was very uncommon for the fans to go bad.
Feb 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
78 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
