Question about Samsung P25 XVC 2200 Notebook
SOMETIMES THE SCRENN IS BLOCKED AND IT4S IMPOSSIBLE TO WORK; I NEED TO REBOOT THE SYSTEM. DO YOU HAVE AN IDEA OF THIS PROBLEM IS IT A SOFT PROBLEM OR A MAINBOARD FAILURE; tHANKS IN ADVANCE; bEST REGARDS
Tip
How to Reboot a Blackberry Without Removing the Battery?
If you remove batteries and hardware while tinkering with electronic devices, you might run into trouble down the line. Blackberry devices must be rebooted time and again, but you can reboot your Blackberry without removing the battery. <br /> <b><i>Instructions</i></b> <br /> 1. When you install a new program or have a system failure, you must reboot the Blackberry. This is the same concept used in larger desktop or laptop computers. 2. Hold off on using the new program by selecting "Later" instead of "Now" when you are prompted by the Blackberry. This will allow you to wait awhile to reboot your device, especially if you need to use it at the moment and can put off the new program installation. 3. Initiate what is known as a soft reboot by pressing and holding down the key combination of Alt+Cap+Backspace on the Blackberry keyboard. Using this method will also work when the device stalls and you see only the white arrow, but it refuses to move. 4. Note that certain Blackberry models are different and require you to press and hold the Alt+Cap+Delete key combination to reboot the Blackberry without removing the battery. Make sure your keypad is correct for using this method of soft reboot before attempting it. Blackberry makes several different models, and they all operate differently under soft-reboot conditions. 5. Reference your Blackberry manual. Make sure that the keypad soft reboot will work with the specific model you are using. Larger models are typically more prone to working with the aforementioned soft reboot. If this does not work, you will have to use a secondary method. 6. Check to see if you need to install an application for your phone that allows for a soft reboot. Many models, like the Pearl, allow you to download an application for soft reboot. These applications may prevent you from pulling the battery to reboot. 7. Try all the available methods, and if it still does not work, request assistance from your Blackberry dealer. She may know of an alternative or a firmware update for your device. <br />
on Jun 06, 2011 | Cell Phones
Expant Shield does not connect anymore. One day it worked fine and since about a week it does not connect anymore. No changes to location, computer, internet connection, etc. Possible that my ISP (I live...
That is a typical problem/issue. What happens is the ip block gets blacklisted and no longer works. All you need to do is wait a few days and it should work again. I think the longest I've seen it down lately is about 4 days or so. Hotspot is pretty proactive on fixing the connections so it usually is much faster. There are a few things you can try such as disconnecting, wait a minute and then reconnect to get a different ip. If the ip is out of the blacklisted range you should be able to watch the BBC/IT4 etc again right away. If not then about all you can do is wait and keep trying to connect. The disconnects I've seen recently are very short compared to when they first started. Those lasted weeks sometimes.
Oct 15, 2011 | AnchorFree Expat Shield
Touch screnn not working
Dropped it? reboot it and see or take it for repair (hope your gurantee is still available)
Oct 14, 2010 | Samsung Star GT-S5233 Cell Phone
My htc mobile windows is blocked
A soft reset basically resets the memory structure in the handheld. This recovers the device from memory conflicts, corrupted system service chains (mainly due to attempting hacks), memory leaks, and system lockups due to the "Fatal Exception" program errors. Removing the battery from the device while it is still powered on is NOT a soft reset and can actually damage the device.
To perform a Soft Reset:
  1. Remove the stylus from the silo located on the bottom right corner (if the device is facing up).
  2. Holding the device face up, the Soft Reset hole is located on the upper right side of the device (the hole is RED).
  3. Insert the tip of the stylus into the Soft Reset hole and the device will reboot
Aug 03, 2010 | Computers & Internet
Whirlpool fridge is fine but freezer not
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again.
Also check to see if anything is blocking any airflow at the vents.
Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 17, 2010 | Freezers
I have a dell Inspiron 1705, it runs fine, boots fast, runs normally however after about 10 to 15 minutes of use the laptop freezes. The only way to reboot it is to hold down the power button to shut it...
Looks like an overheating problem.
First, make sure that you put your laptop on some hard surface. If you put in on your bed for example, the soft surface will block the air vent on the bottom of the laptop, resulting in poor cooling of the inner components.
Do you hear the fan working, and air blown out of the exit vent on the side (or rear) of the laptop?
If not, then perhaps the fan is broken and needs replacement.
If the fan can be easily heard, working at full speed all the time, there is a problem with blocking the air inlet, or the internal radiator/heatsink got covered with dust and lint, and needs cleaning - try compressed air blown from the opposite direction (from the air outlet) to blow away the dust - of course with the computer switched off, otherwise you'll be "fighting" the fan trying to blow in opposite direction. If this doesn't help, the laptop needs servicing, as it probably lost the heat-conductive layer between the processor and heatsink.
Jan 23, 2010 | Dell Inspiron E1705 Notebook
Htc 6800 has to be soft rebooted after screen goes dark
Take the phone back and get another one. This is a store queen. Bad manufacture maybe. You should be able to keep the phone on long enough to upgrade system. Also, the numerous reboots might be from a short in the on/off switch. Either way I would get it replaced.
Apr 08, 2009 | HTC PPC-6800 Smartphone
I have an HPDV2000
You need a new hard drive. Sorry.
Aug 18, 2008 | Computers & Internet
Samsung P25 XVC 2200 Notebook Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
