Question about Dymo LabelWriter 310 Printer
Won't turn on
Dymo labelwriter 330 won't turn on
  • 43 Answers
The 330 series don't have an on button (they are on all the time, unless you unplug them), so presumably you are saying it is plugged in but the light is not on, the button on the front doesn't respond, and it doesn't print.
I'll assume that you have checked that the power supply is plugged in to a known working power socket and the socket is switched on if applicable (depends on country), and that you have checked the power cable is firmly plugged into the labelwriter.
Check to see if the power supply has an LED on it. If it has but it is NOT lit, and is definately plugged in then it is probably a dead power supply (or possibly a blown fuse).
In this case you can try a replacement power supply: Dymo LabelWriters (2nd item from bottom)
If the LED is lit then it would suggest that the labelwriter is broken.
Posted on Oct 09, 2009
  • djroedl Jul 22, 2011
    My Dymo Labelwriter 330 does have an on/off switch. It's on the back of the unit. Checked it in several outlets. The power supply is internal. There is a status light. But no power when I toggle the switch.
Light is blinking and won't print labelsbet
If you like my solution, please give me 4-thumbs up rating.
Why is the light on the front of my Model 330 LabelWriter blinking?
There are 5 possible reasons for this:
  1. The labels are not left-justified
    • Verify that the labels are left justified and loaded properly in the LabelWriter. Click here for more information on loading the labels in the LabelWriter.
  2. There is paper dust or a piece of a label blocking the sensor
    • Take the roll of labels out of the printer and use the provided cleaning card to clean your unit. Click here for more information on using a DYMO Cleaning Card. You can also use compressed air by blowing some air along the left side of the paper path inside the printer.
  3. The labels you are using do not have the index marks properly cut out between each label
    • If the index holes are not cut cleanly, you may run into this problem. Try a different roll of labels.
  4. You are not using DYMO labels
    • If you are not using DYMO labels (or are unsure whether or not you are), please obtain a roll of DYMO labels and try to print again. DYMO labels are made specifically for our printers.
  5. The photo sensor that reads the index mark has failed
    • If this is the case, the unit will need to come in for repair. Select the Ask A Question tab at the top of this page to contact our Technical Support team. Please include the following information so that we can set up a Return Material Authorization (RMA) for you:
      • Full Name
      • Full Shipping Address (No PO boxes)
      • Phone Number
      • Date of Purchase
      • Model Number (a 5-digit number found on the bottom of your LabelWriter)
      • The 11-digit number under the barcode on the same label
      • Serial Number (located on the bottom of the printer, starting with "S/N" -- it also contains a dash after the first five numbers)
      • If your unit is out of warranty (beyond 2 years from the original date of purchase), please provide us with a method of payment (including expiration date, if using a credit card). The cost to repair your unit is either $75, which includes UPS Ground return shipping, or $90 for UPS Next Day Air return shipping. Please let us know which return method you desire.
Aug 04, 2011 | Dymo LabelWriter 330 Thermal Printer
Our old computer crashed and when I installed Dymo on our new computer, the label size we always used isn't installed. I need label size 30336. Can you help?
I just looked through all the preconfigured labels on my Dymo 330 and did not see a 30336 label. Is it possible you configured this manually or had it inserted from some other program you loaded? It's easy enough to configure a label manually. You might also call Dymo tech support.
Jul 18, 2011 | Dymo LabelWriter 330 Thermal Printer
What is the life expectency for these? Mine doesn't come on even with the AC plugged in
We've had our Dymo 330 Turbo for years and still use it daily to print all our address labels - never had a problem with it. They come with a 3 year warranty, so I guess Dymo thinks they're going to last at least that long.
If the power supply has had it you can get a replacement power adapter but if the machine has had it then time to get a new one I think.
The 300 series was discontinued years ago, and even the 400 series has now been discontinued and replaced by the Labelwriter 450 series.
Oct 24, 2009 | Dymo LabelWriter 330 Thermal Printer
Only prints on bottom half of label.
Your scanner and thermal printer has got loose connection. Print head also may need cleaning by own system. try from the software.
JMC
Aug 12, 2009 | Dymo LabelWriter 330 Thermal Printer
Dymo 330 printing cartridge
Try cleaning the print head with a Q-Tip dipped in alcohol.
Lou
Sep 16, 2008 | Dymo LabelWriter 330 Thermal Printer
Hi, i am on vista at the moment but it will not reconize the usb port for the dymo labelwriter
THe printer is not compatible with the current drivers on the disc, there for you will have to go to www.dymo.com for current drivers, but unistall the printer from you decktop,pc before installing.
Apr 23, 2008 | Dymo LabelWriter 330 Thermal Printer
Dyno Labelwriter 330
Here is the link for your software. Just scroll down to get to your operating system and you can download everything you need. Hope you weren't waiting long. If this solves your problem please rate this as fixed. So many people forget. If you need more help just add a comment and I'll be glad to assist you further. Thanks. Please,dont forget to rate as fixed. Have a nice day.
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=101
Apr 20, 2008 | Dymo LabelWriter 330 Thermal Printer
Dymo LabelWriter 330 print problem
Try first unplugging PC power cable for 5 mins. Unplug Dymo usb. Plug everything back and restart.
If it does not work, then do the following.
Uninstall the printer completely, also remove all Dymo printer software. Then restart the pc and re install all sofware and drivers. Start installation with Dymo disconnected.
regards
Mar 01, 2008 | Dymo LabelWriter 330 Thermal Printer
Dymo LabelWriter 310 Printer Logo
746 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
