Question about Insignia IS 20" TV040919 TV
24"insignia tv blue&green picture
I have the exact same problem with mine. It has a green screen. I was told that the color piece went out in it, but i don't know where i can go to get it fixed.
Posted on Jan 23, 2008
Im trying to connect my sega dreamcast which has red white an yellow av cable only, however my insignia NS-32E570A11 led tv only has for component connection with the blue green n red, when i hooked it up,...
Sorry, this will not be easy....
You need to locate a composite to RGB converter box.
Your Sega outputs a composite signal - Video (yellow) and audio left/right (white/red).
The TV needs RGB (red/green/blue) inputs on the component connection...your composite signal divided by three. There are converter boxes out there for around 70 bucks or so.
Are you certain you do not have a yellow VIDEO IN jack on your set? Every LCD and LED TV I have experience with has at least one.
Feb 18, 2011 | Insignia 42" LCD Flat-Panel HDTV
I'M TRYING TO HOOK UP MY INSIGNIA 42'' 1080P FLAT-PANEL LCD HDTV TO OUR DVD PLAYER USING THE COMPONENTS (RED, BLUE, GREEN, RED & WHITE CABLES) PROVIDED AND THE PICTURE IS IN BLACK & WHITE....
The three picture cords (red/blue/green) often are a little larger around than the sound cords (red/white). If they are they same size, they are often grouped separate by picture and sound. Double check to verify if you have the "red" cords correct. Good luck.
Jan 20, 2011 | Insignia 42" LCD Flat-Panel HDTV
I have a insignia LCD 32'' TV and it have sound but the screen is green please help i use the component blue green and red
It sounds like the RED cable is not connected right, you did not mix the RED for audio right channel RCA plug with the RED component RCA plug? Please verify the RED, BLUE and GREEN cables again just in case, otherwise t can be the source component or the processor inside the TV.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 19, 2010 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Insignia 24'' flat tube, peolple orange tint
It sounds like the electronic ciruitry tha fire the Blue Gun of your CRT is not working. It could be as simple as a cold solder joint in the circuit (very common) or a malfuntioned component. I wouldn't advise repair by yourself due to the High Voltage and the risk of CRT Implosion. Any reputable PC or TV Repair Shop should be able to repair pretty cheap.
Nov 12, 2009 | Insignia NS-24 TV TV
Insignia lcdtv32 poewr on but no picture
You need to check the 12 or 24v source coming from the power supply to the inverter board, that's the board usually to the left and rather tall. Get your meter set, then turn the set on and see what happens, if the voltage comes up and then shuts down, you'll need to pull the plug for the inverter and measure the voltage again. If it stays up you have a bad converter board, if not then it's in the power supply, that's good old fashion trouble shooting from there on.
Feb 26, 2009 | Televison & Video
Bush lcd 24 inch tv
REPLAXCE THE DEGAUSING P.T.C
Oct 24, 2008 | Bush 5693D 24" TV
Coloration - poor picture
TRY UNPLUGGING SET FOR A FEW MINUTES...PLUG IN LINE CORD WHILE HOLDING PRESSING POWER BUTTON..IF THIS DOES NOT WORK..CPU BOARD IS FAILING...P/N 667-L32K5N-56I...TRY CALLING MCM FOR PARTS AVAIL/PRICE...JOE ACE
Jun 05, 2008 | Insignia IS-LCDTV32 32 in. Television
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
The picture is only producing the basic colours red green and blue
Can you post a picture of the Tv with the issue stated?
Feb 28, 2007 | JVC AV-24F703 24" TV
Insignia IS 20" TV040919 TV Logo
185 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
