Question about Nokia N95 Cellular Phone
Battery does not charge, - Nokia N95 Cellular Phone
  • 11,896 Answers
Either battery pack is dead, or the ribbon cable from battery pack to main circuit board is faulty. You can also test with a multi-tester or voltmeter to see if there is power coming out of power supplyt/charger
Posted on Oct 08, 2009
Had this tablet for one day, its showing 50% .. battery, when should I recharge..
There's no harm in keeping it on charge all the time. Unlike older rechargeables, newer Li-ion batteries don't need to be broken in by running them down and then recharging.
Feb 12, 2015 | Tablets & eReaders
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
My battery will not charge in charger
The charge adapter may be faulty.
OR
If therecharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 14, 2012 | Nikon Mh-16 Digital Slr Camera Battery...
The bike dies, after a fully charged battery.
Bike has magneito (thats spelled wrong ) On line youtube veido shows how to fix that.
Apr 01, 2012 | MBK Motorcycles
Why does my 18v battery only take 1/2 charge?
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 25, 2011 | Milwaukee Tool V18 Battery
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
I have new laptop how many hour battery charge first time
First Time Charging
  • The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
    When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
  • Read more: For How Long Should One Charge a New Laptop Battery? ' eHow.com http://www.ehow.com/way_5261076_long-charge-new-laptop-battery.html#ixzz1GTAFQEz9
    Mar 13, 2011 | Acer Computers & Internet
    Battery charge indicator seems faulty.
    Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
    Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
    Nokia N95 Cellular Phone Logo
    42 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
