Hi Magicbyrdman Two questions about the 50.2 error message - fuser guidance you posted. Is the fuser located in the rear / bottom of the 2840 Laser jet? What color are the lever near the gears? (the one that needs to be pushed in?) Many thanks
    President:
  • 1,314 Answers
Hi. The fuser is in the rear of the printer. Here is a picture from the service manual: Sorry it's not very clear. You can download it from here. Hope this helps. If it does, please take a moment to rate this solution as fixya.
Posted on Dec 10, 2009
I'm tyring to print this morning and message comes up need to order supplies, then I look what I need and change it but this message error keeps coming up 50.2 fuser error before and after I change the...
When a 50.x fuser appear its because the fuser its worn, its probably overheating. I can suggest to take it out (in the back you will see 2 blue locks) for about half hour (turn the unit off before you are doing that) and put it back in. If the error persist you need a new fuser. Good luck
Aug 23, 2010 | HP LaserJet 2840 All-In-One Printer
HP Color LaserJet 2840 keeps showing 50.2 Fuser error message. Nothing helps correct problem. What to do? Have tried repeatedly turning printer off, waiting several seconds and turning on again. Each time...
The fuser is the heating unit near the paper exit, and that error means the lamp is burned out, the overtemp sensor is out, or the thermistor in the fuser is bad. About all you can do is replace the fuser. www.precisionroller.com will have a new fuser for you.
Jan 12, 2010 | HP LaserJet 2840 All-In-One Printer
The hp color laser jet 2840 does not print. message "50.2 fuser error" appears
HP recommended checks: 1. adequate 120 VAC power supply, 2. Remove Fuser Assembly, wait 5 minutes and then reseat. 3. Reset the printer to Factory Default settings (remember to copy down the IP address, mask and gateway numbers first).
While this may solve the problem, it is much more likely it's time to replace the fuser. Cost is approx $125 if you buy it online. Just do a Google search on HP 2840 fuser.
This link will show you where your fuser is and how to remove and replace it.
http://h20464.www2.hp.com/resultsCSR.htm?prodSeriesId=445194&MEID=631309C6-088F-43F9-931F-604BAE10EB69
Oct 21, 2009 | HP LaserJet 2840 All-In-One Printer
My HP Color Laserjet 2840 and is saying "50.1 Fuser Error"
HP error message 50.X is usually a fuser error. replace fuser
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
50.2 Fuser Error in HP Laserjet 2840
Printer connected straight to wallsocket,?check the fuser, remove it check for damages, and put it back, if error persist buy a new fuser.
Nov 10, 2008 | HP LaserJet 2840 All-In-One Printer
Need to order a replacement FUSER it's located in the rear of the printer. If you live in the USA you need 110V if you're in Euro 220V see below for the part number you need to order.
RG5-7602-000
RG5-7603-000
Fuser ***'y, 110V, CLJ 2820/2840
Fuser ***'y, 220V, CLJ 2820/2840
CLJ 2820/2840
Aug 06, 2008 | HP LaserJet 2820 Printer
Hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
2840 printer 50.1 & 50.2 error dometimes 13.0 error
Thanks CoolDragon. Ifollowed your advice and eventually replaced it.
After trying to pull out and reseat the fuser a few times (I would even get one or two prints out of it each time), I finally ordered another fuser and problem has gone away. I did google and purchasing site searches (pricegrabber, pricewatch, etc) and found a decent priced site, that also gave discount for your returned bad unit (they gave you so many days to return it), otherwise they'd charge your credit card for the extra dsicount they had origanlly given.
Dec 14, 2007 | HP LaserJet 2840 All-In-One Printer
32 people viewed this question
k24674
jasbo
jasbo
