Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Yamaha 1998 25 hp 3 cylinder outboard pistons hitting spark plug
I set the gap on my spark plugs, run the boat in the water for 30 minutes, remove plugs and they are slightly closed. i looked at the top of all the pistons and there is a small clean mark where it appears the pistons are hitting the plugs. i can run the motor all day and it runs fine. is there another reason for this other than the wrist pin or rod bearings going bad. it is almost exactly the same on all three plugs
  • 677 Answers
This must have the wrong plugs in the motor.The gap between the top of the piston and the plug is about 8-10 mm.No motor will run with any bearing that is that worn.You said you looked at the top of the piston.With the head off,did you check how far the spark plug extended through.The reason being,is that it should not protrude all the way into the combustion chamber.It must have the wrong length plugs in it.If it runs well,you have the heat right.Mate.Hope this helps
Posted on Oct 09, 2009
Johnson 6hp model 6R710 need details
Basic check for any outboard: check compression in each cylinder, should all be within 10% of the lowest reading. With an air gap spark tester check spark. Your 6 HP spark should jump a 3/8" gap, blue crisp spark is good, yellow weak. Check gear lube with the motor in a verticle position, prop end down, unscrew the drain plug at the bottom of the gear case. Let a couple of drops out. Should be clean gear oil. If old it might be black and have a strong odor. There should be no water or metal filings. If it is milky there is water mixed in with the oil. If all checks ok run the motor. It should run smooth, no knocking and the cylinder head should be about 120 degrees. That is uncomfortable to keep your finger on but not so hot you cannot touch it. If it is too hot or too cold it can cause problems if run. Too hot will cause problems very soon, too cold will cause problems over time by building up carbon in cylinders and causing piston rings to stick.
Hope this helps.
Apr 20, 2014 | Boating
Yamaha 2.5 hp outboard motor spark plug gap
I Would Recommend a 0.8 Gap
Mar 10, 2013 | Boating
Yamaha 200hp 2001 manual
  1. Fuel
    • A common problem with an easy solution, Yamaha boat engine trouble could arise due to inadequate levels of fuel or engine oil. All Yamaha outboards take unleaded gasoline as a main fuel source with a pump octane rating of 86 or higher. The type of engine oil varies according to motor size and can be found in the "Specifications" section of a particular outboard's owner's manual (See Resources).
    Electrical
    • Problems with the electrical system can also prevent a Yamaha outboard's engine from working correctly. Troubleshoot the electrical system, first removing the main fuse that's located underneath the electrical panel on any electric-starting outboard. If the connection at the center of the fuse is broken, it must be replaced by a fuse of the same amperage. The battery should also be removed, cleaned and fully charged when troubleshooting the electrical system.
    Spark Plugs
    • Owners should also remove and inspect the spark plugs during the troubleshooting process. If the insulator tip of any plug is burned, that spark plug should be replaced. The number and type of spark plug depends on the specific outboard. Additionally, owners should ensure that each spark plug gap is set to the width stipulated in the owner's manual (see Resources).
Jan 20, 2013 | Motorcycles
Spark plug gap for 2004 150 hp yamaha outboard
2004 mercury 150hp,v6 2stroke,spark plug gap
Jan 18, 2012 | Boating
Yamaha outboard 150 4 stroke bad vibration at 700 to 1200 rpm run great in nuetral and over 1200 rpm what could it be
is you propeller bent? a dent the size of a quarter will cause a shake. If not that means your engine is misfiring. here are the troubleshooting test and tool list you need to find out. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local outboard dealer. I know all these are expensive but if your going to be a outboard tech you will always need them. Troubleshooting (1) check compression. without the year model I'm giving you a average numbers. Look at your Clymer manual. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine coul clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing its fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Nov 03, 2009 | Boating
Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Sep 29, 2009 | Boating
I have a 90 hp that idles fine but bogs down when I open the throttle and shuts down. Can you help?
Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard tech you will always need them. Troubleshooting (1) check compression. without the year make and model I'm giving you a average numbers. Look at your Clymer manual. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine coul clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Refer to your Clymer manual about cleaning carburetors if its carbureted and not fuel injected. Fuel injected will require more tools and alot more test. I love clymer manuls
Sep 23, 2009 | Boating
Not getting gas to motor on 150 efi,engine will try to turn over
need year and make? Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. Troubleshooting (1) check compression. without the year and make I'm giving you a average numbers. Look at your Clymer manual for specific specs. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten .Ethanol gas is proven to stay stable in fuel systems for only 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine cowl clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the make so I guessing what fuel injected system. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works. without the test information I would guess the electric fuel pump. but test everything first because a mercury efi fuel pump will set you back 600.00
Sep 15, 2009 | Nitro Boating
Skipping, lack of power, 4 stroke mercruiser
has your boat been sitting more than 60 days. ethanol gas has been proven to only stay stable for 30 days in 90 degree + weather. Labor cost can be up to $100.00 per hour. CHEAP TEST- compression, spark, and fuel. TOOLS(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. TROUBLESHOOTING (1) check compression. without the year model I'm giving you a average numbers. Look at your Clymer manual for specific numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing its fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Sep 08, 2009 | Light Outboard Motor Boat Bass Fishing...
Yamaha 30 HP 3 cylinder 2 stroke
pull the spark plugs and see if they look like there burnning the same if so then i dought its a spark issue and if it was in the lower unit u wouldnt here a loud anything it sounds like a rod bearing i have had the same thing happen to several yamahas under a load
Jul 06, 2009 | Light Outboard Motor Boat Bass Fishing...
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
537 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
