My dx3800 paper feed jams on one corner - Office Equipment & Supplies
RPFinney
  • 385 Answers
SOURCE: HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
Posted on Apr 16, 2009
  • 199 Answers
SOURCE: Canon ip1800 will not feed paper...One side jams
canon has a friction feed system,
clear the paper path and check if there are any small paper peace,
clean the pickup roller by a waterized cloth,
proper set the paper guide and try print again.
Posted on Jun 25, 2009
SOURCE: Will not feed paper of any size. No jams ever.
clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
Posted on Aug 15, 2009
pineworks
  • 4041 Answers
SOURCE: paper won't feed through canon printer. no paper jam apparent -
Hello there gave it a go this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
  • 10406 Answers
SOURCE: paper is pulled into printer unevenly causing paper jam
Look closely at the "path" that the paper takes through the printer -- you probably have a small piece of paper stuck somewhere, that is causing the paper-feed to get "skewed".
Failing that, take the printer to a qualified technician.
Posted on May 27, 2010
Lexmark s605 paper jamming
Sounds like an obstruction on the right hand side of the feed mechanism. All-in-ones are a pig to find these - I've had one HP almost completely stripped before I found a chad of plastic stuck in a corner. Nine times out of ten it's a torn corner of the first bit of paper to get chewed jammed in the feed slot.
Apr 06, 2012 | Lexmark Interact S605 All-in-One Color...
The paper alwayes jamming
If paper is consistently jamming, there are two usual suspects: worn feed rollers or a physical obstruction. If the paper comes out with a crease or dog-eared corners, you most likely have some sort of debris blocking the paper path. However, if the paper doesn't have any creases or bends, then the feed rollers have most likely worn out or need to be cleaned. For obstructions, I would suggest manually feeding a thick piece of card stock through the machine in hopes of clearing out any debris or stuck paper bits.
-David.
Nov 02, 2010 | Office Equipment & Supplies
WILL FEED PLAIN WHITE PAPER BUT WILL NOT FEED PHOTO PAPER
Follow the steps:
•1
Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
•2
Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
•3
Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
•4
Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
•5
Print your documents as needed.
Paper Cassette :
•1
Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
•2
Pull on the cassette on the bottom of the printer to slide it out of the printer.
•3
Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
•4
Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
•5
Slide the cassette back into the bottom of the printer. The printer is ready for printing.
Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
Paper feed jamms the paper all the time, will not feed without jamming from bottom tray, top tray jams every 2 to 3 prints or print with the top corner bent
Unless both feeder rollers went bad at the same time, which is unlikely, it must have something to do with the paper. It might be slightly damp, or not the correct kind. Try using high quality matte white paper from a brand new pack and see whether it still jams.
Oct 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Paper does not go into the printer. One corner of a page will go down a bit but not the rest. There is no paper jam or any other difficulty.
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Sep 16, 2008 | Office Equipment & Supplies
Paper feed jamming problem
had this problem also try looking for a tiny piece of torn paper in the feed wheel and remove the snag
Aug 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Top paper feed jams
if your feeder is jamming you need the roller & pad replaced and usaaly the internal feed roller cleaned this is a repair that should be done by a sharp tech about a $150
Jun 30, 2008 | Sharp AL 1631 Copier
Paper jamming and feeding unevenly
I have the exact same problem. Until last night it worked perfectly, and when it ran out of paper, I put more papers in the back of the printer correctly and since then it won't print, it pulls paper to the right and the paper jams. I tooked the printer to the service and they say that I'm lucky that the warranty did not expired yet, cause the problem is a "manufacturing mistake", and that they will take it to the Canon service.
I realy hope they will do the job. I'm expecting to repair be done till tomorow.
Apr 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Curled corner causing a paper jam
Try replacing all paper. Sometimes paper that is overly humid or has gotten wet will curl. Replace with new paper and report results.
Dec 17, 2007 | Dell 1600n All-In-One Laser Printer
41 people viewed this question
k24674
