Question about Panasonic Lumix DMC-FX01 Digital Camera
Camera lens damaged, have a dark shade on left edge of viewer
Camera lens was damaged on one side from a blow. Now there is a dark shade on left edge of viewer when you focus for pictures.
    Novelist:
  • 194 Answers
If you are able to take photos then I suggest you make a few to figure out if they are also dark like the viewer edge. If they are OK, enjoy the camera while it lasts and perhaps you can adapt to not having a clear view to the edge. I recommend against spending the money to repair this camera as it will likely exceed the cost of replacing the camera.
Posted on Oct 08, 2009
Testimonial: "Received what I thought was excellent advice,in a timely manner"
I have a haze effect on only one side of my picture
If a haze is on the lower part of the screen, and picture, that means something is wrong on the upper side of the sensor. It is almost impossible it has to do with the lens. Although you can look if the front of the lens is clean. Only clean a lens with a lens pen and not with any fluid or paper towel.
I just wonder if the camera was in a moist environment for a longer time. This could be the reason a part of the sensor has changed. Something like mould can have grown on the sensor. If that is true, I don't thick it is worth bringing it is for a repair.
Jan 13, 2014 | Nikon COOLPIX S3300
Hello, I have 2 problems with my Panasonic Lumix DMC-FS4 Digital Camera. Firstly, at the lower left corner of my screen, there is a dark shade. So in all my pics, there is sth black on the lower left...
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 28, 2010 | Panasonic Lumix DMC-FS4 Digital Camera
Samsung LN-T4661F with black shaded area.
The back light is beginning to fail, thats why it goes shaded but you can still the picture on one side, do a google search for back lights for your make and model, there a few how to's to help you with changing the back light.
Feb 17, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Error
This is an error that plagues many different brands and models of camera. It's often the result of the camera being dropped, or of it getting dirty inside the lens housing. Basically, the electronics inside the camera are detecting a sticking point between the lens and the body and shutting down to avoid further damage.you can try the following:
  • Make sure the lens isn't visibly sticking anywhere. Look around the edges of the lens and see if it's making contact with the body. If it is, try to gently center it and then attempt to turn the camera on.
  • . Try using compressed air (not too high pressure, obviously) to blow around the edge of the lens.
  • Last of all, I have read several stories about people gently "banging" on the bottom of the camera just below the lens. I guess it couldn't hurt .Well... I guess if there are no other choices,,,alrighty then!
Sep 29, 2009 | Cameras
Subject is dark when looking through the viewfinder
Take the lens off and look at the lens opening on the body - at the 9 o'clock position is the aperture stopdown lever. It should be square to the edge - not bent sideways or too far from the side. It's a pretty flimsy lever and easily bent. You can bend it back square by grabbing with pliers and pushing toward the left side. Common problem.
May 07, 2009 | Nikon N65 35mm SLR Camera
The camera is developing dark areas around the edge of the pictures on 2 different sides. you can see these dark spots on the viewfinder and on the pictures. what is causing this?
If your lens is clean.
The dark spots maybe your image pickup sensor going out. Try going into the menu to tools select pixel mapping see if that helps it will look at all your pixels and determine if they are bad & try to compensate.
Hope it helps. Good Luck! please let me Know if this works or if you need more help.
Mar 11, 2009 | Nikon Coolpix 4800 Digital Camera
Blurring on one side - Viewing and photo
A friend managed to find a very easy solution to this problem...the lens was dirty due to a 6 year olds sticky fingers...so I just needed to clean it.
Nov 06, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Uneven flash
Look carefully at your images taken with flash... on the horizontal image is the lower part of the image slighty darker and have a rounded fall off at the edges? Is the vertical image dark side a straight hard line or is there a rounding to the top and bottom?
What we are looking at is if you have a very wide angle lens with the lens shade attached to the lens, then the built-in flash catches part of the lens shade and make a shadow on your subject... take the lens shade off and try the same shot and see if that makes a difference...
Have a great day...
Ed
Apr 03, 2008 | Nikon D40X Digital SLR Camera Digital...
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Lens error
Does it stay when you turn it off and back on again? These cameras have a function that shuts the camera down when there's a mechanical obstruction to the lens extension, It shuts it down to prevent more serious damage to the mechanism. Problem is, sometimes when triggered it doesn't return to normal. Try resetting it, either by the regular procedure, or by taking out the batteries for a few minutes. keep in mind that the lens barrel of this Casio unit is almost all the way to the left edge of the camera. Inevitably, when you hold the camera with two hands, one of the fingers of the left hand will overlap onto the front left edge of the unit, which, in fact, puts a portion of the finger on top of the edge of the extending lens barrel, either slowing its extension outward or aborting the extension process altogether. Even when you instantly jerk your finger away instinctively when the barrel rides the edge of your finger, you still have affected or interrupted the barrel extension process. In my opinion, a design flaw, but who am I to say? Good luck ;]
Jun 02, 2006 | Casio Exilim EX-Z4U Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
139 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
