Question about Kenmore Ovens
The oven, which is mounted on the wall next the the stove, doesn't get hot. I had an elecrician in and he said it wasn't the heating element. In fact he said the heating element for the broiler is working it's just the top heating element for the oven that isn't making the oven hot. What part or parts do you suppose might be required?
    Guru:
  • 310 Answers
1. There are 2 elements, bottom one is the bake-element, top is the broil. Does the bake element glow when it cycles on?
2. The temperature sensor could be faulty.
3. The control board may have failed. We see this symptom frequently due to a control board problem. We repair these at www.fixyourboard.com
Posted on Oct 08, 2009
My wonderful oven is malfunctioning. The grill works fine and the fan spins but the oven won't heat up at all. Any suggestions much appreciated.
Sorry Anon, but there are tons of ovens manufactured, so with no make & model I can only suggest that you try to check to see if you have any fuses or breakers popped - You'll have to find these yourself.
Next the grill is the top oven element, the oven heat comes from the bottom element as heat rises. Is this element burned out?
You will need a multimeter and a screwdriver.
Remove the back of the oven, after you have pulled it out from the wall and unplugged it from the wall. Then unscrew whatever portion of the back of the oven that will expose the bottom element, disconnect one end of the element from any wiring of the stove, and using the meter on Resistance setting, see if you get a relatively low resistance reading - If not, then the element may have died.
If you can't figure how to access he ends of the bottom element, then you need to get someone who can help you or sorry, call in an appliance repairman
Mar 12, 2015 | Ovens
We have a GE electric stove with a JDP 39 oven element which has burned out. How do we get the bottom heating element out to replace it?
UNPLUG the stove or turn off its breaker.
Inside the oven, trace the element back to the rear wall. There should be one screw on each side next to where the element goes through the rear wall. Unscrew that screw on each side and pull the element toward you - it'll come easily, bring its wiring behind it (this is why there must be NO power to the stove!). Detach the wiring from the element... DO NOT allow the wires to pull back through the wall, or you'll have to pull the whole range out to retrieve them.
To install the new element, just reverse that procedure.
Jul 31, 2014 | Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Removing oven element to install new one
Turn power off at service panel (220 volt circuit breaker). Remove screws from heating element mount on wall of oven. Pull heating element from wall of oven far enough out to see the where the wires/lugs are screwed to the heating element leads. Remove these screws. Replace element. Make sure screws on heating element lugs/leads are tight -- if not tight, arcing will occur.
Charlie
Jan 08, 2011 | Ovens
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Feb 11, 2008 | Amana AOCS3040 Electric Single Oven
Oven and stove top not getting hot.
The most probable cause is that the heating elements are getting 110V instead of 220V. Check the voltage to the heating elements.
Sep 07, 2007 | Ovens
HOTPOINT ELECTRIC STOVE
two things---when you open the oven door do you see a button on the right or left side?if so thats a door switch and if its bad you will get no voltage to the element.the next thing is your hi limit is bad.this is a sensor that monitors the temp of the oven and if its bad you wont get any heat.some hi limits reset themselves others you have to manually reset them.let me know.
Jul 30, 2007 | GE JKP15 Electric Single Oven
Ovens Logo
103 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
