Portable Air Conditioner & Heater
Wont throw out heat, the hightest I can get is 64 even when I set it at 90.
Thank You:
Larry
  • catdogbird11 Dec 13, 2008
    Whirlpool heat and air unit. Don't know the model. Heat is lukewarm coming out .
    Scholar:
  • 72 Answers
What brand and model #? If it's a heat pump, it could be the crossover valve, in which case you might as well get another unit, they are expensive to buy and you have to pump down system and it's a big head ache.
Posted on Jan 27, 2008
Why can't lower the setting more than 64 on my portable bpact10 air conditioner
It could be it is set up with that limit in the main set up menu if there is one.
Any air conditioner set colder than normal will develop problems prematurely unless it is engineered for that type of application.
Oil is needed in an AC system, for lubrication. Oil will accumulate in colder than normal places in the AC, this may starve the compressor of oil.
If that is your need, get a walk-in fridge or sort of one.
Aug 06, 2018 | Heating & Cooling
Cleaning a haier portable air conditioner
I have a portable Haier Commercial cool and I had the same problem. I did regularly clean the filter. Finally I decided I was either going to throw it away or have to open it up for a thorough cleaning. I don't even want to describe the disgusting dust build up inside. Surprisingly the water reservoir was not so bad. I am sure they don't recommend it but I was able to remove the front and back panels, vacuum thoroughly, wipe down the insides and reassemble and it works like new again. It is unreasonable for things like this or fans to be expected to run for years without a proper cleaning. The manufacturers must have disgusting home standards.
Jul 09, 2014 | Haier America 12K BTU Portable AC & Heater...
What causes the exhaust hose to get hot on a windchaser portable AC
make sure its not obstructed, then wrap it up with a towel or other insulative material. it heats up because the heat exhausts through that hose out the window.
Jun 28, 2014 | Windchaser PAC9 Air Conditioner
Amcor 10,000BTU set at 64 degrees - - temperature of air coming out of unit is 72 degrees. In one and half hour set at 64 degrees the room temp only went from 90 degrees to 84 degrees. Recommendations?...
I am not sure, i have a similiar unit that is brand new, seems like a faulty mechanism from the maker, it starts cold for about 2-3 minutes and then shuts down condenser and blows hot air repeating this cycle. I don't believe it ias a recharge, just a faulty machine
Jul 15, 2010 | Amcor PLM-14000E Portable Air Conditioner
I have a duo therm air conditioner think thermostat problem
Google dometic rooftop air conditioning parts!Wouldnt suggest using off brand parts maybe diffrent?if that one is set up for 12v also maybe deffinatley diffrent!!!Try cleaning condensor aluminum fins on roof top if condensor is dirty will throw whole system out of whack!!!use oven cleaner and hose with nozzle be careful not to bend fins throughly rinse off cleaner after soak period spray off completly off roof and sides quickly!!!!!may damage decals etc!!! anyhow try that before replacing parts then use factory or alike parts!!!Good Luck!!!
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
THERE'S NOT A PROBLEM I NEED YOUR OPINION
This EdgeStar 10,000 BTU portable air conditioner heats and cools for year round comfort and is recommended for room sizes up to 350 square feet. This slim and light superstar uses the latest technology to squeeze the most powerful cooling from the smallest possible package this 10,000 BTU portable air conditioner has a footprint of just over a square foot and is under 28andquot high! This portable air conditioner is the most powerful portable air conditioner in its class and size range and can bring down mid size rooms faster than competitor's models.
Dec 27, 2008 | EdgeStar Portable Air Conditioner Heater
Newair mod# ACP-1600E/H Series
Because it's not a heater. Don't ask me why the thermostat goes to 90, probably because it's an import from a country with no quality control. But I haven't found any supporting literature that says it operates in anything more than cooling mode. You can split the case and see if there's a crossover valve (where three lines go into a sideways cylinder with a solenoid on one end) near the compressor which means it's a heat pump or if there's an electric heating element near the evaporator which means it's standard heating. If so, then get back to me, but if not, you only have an air conditioner.
http://www.airconditionerstips.org/newair-ac-1600e-portable-air-conditioner.html
Dec 24, 2007 | Heating & Cooling
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
