Question about E-Machines M2352 Notebook
Lost audio. Could have been when I was cleaning up files in the control panel.What can I do?
Samsung n130 lost the audio
I assume you went to control panel, clicked the speaker icon, and went through all the different options (it is sometimes complicated, with different volume settings for different file types depending on the audio driver/soundcard). Sometimes (like in Vista) you have to select the default audio source, sometimes some are hidden unless you ask it to show disabled devices.
Apr 18, 2014 | Samsung N150 (36725723009) Netbook
I lost my laptops sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 11, 2011 | M-Audio Audiophile 192 Sound Card
I reformat my TM C6868 desktop. I lost the driver so the audio is not working now. There's no problem with the sound card.
also
hope this helps
Jun 04, 2011 | Computers & Internet
Lost sound,
also
hope this helps don
Mar 14, 2011 | Computers & Internet
HOW DO I REPAIR MY LOST SOUND ON WINDOWS XP
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 20, 2010 | Computers & Internet
No audio
never delete files from ur Control panel>
go to Control panel and try and check for the Sound properties> find them and chk if the Speakers are selected as the default or not>
Still if doesnt respond> search in google and download the latest Codecs on ur computer
Oct 08, 2009 | Intel Premier Resources 4-Channel 32-Bit...
Lost strings32.dll can't reload programme
Try to download the file from here and use it in your computer :
http://www.dlldll.com/downdll/6250.html
Hope that solve the problem
have a nice day
Please rate my answer
Oct 07, 2009 | Magix Audio cleaning lab 3.0 Full Version...
JVC CarAudioModel KS-RT404 lost rear panel containing connections
http://files.ddrservice.info/Audio/jvc/ks-rt404.pdf
This link will take you to the manual. On page 7 you will find the connection Info. you need.
Sep 18, 2009 | Car Audio & Video
I have lost the volume control icon from the desktop toolbar and want to restore it
To display the volume icon in the taskbar notification area, you must select the "Place volume icon in the taskbar" check box in Control Panel Sounds and Audio Devices applet.
May 21, 2009 | Dell Inspiron 1501 Notebook
Open Questions:
My E-machines laptop's internet connection is slow via Wi-Fi. My e-machines laptop does not connect to the internet at full speed when on the Wi-Fi network however on Ethernet it will connect at its full speed. Now I know Wi-Fi does tend to be slower than direct cable connection however I do have other laptops in the house and they all produce the following results on broadband speed tests on the internet: E-Machines laptop: 4.7 Mbps (seems to cap out at this speed) Other laptop(s): 5.7 Mbps This only happens in my home network because if I take my E-machines elsewhere to other networks it can reach higher speeds. So that rules out that something is wrong with my Wi-Fi adapter built into it. I currently have At&t U-Verse service with a 6 Mbps internet service with a 2Wire Router/Modem Gateway. I had a technician from At&t come out and he checked the router and said it was fine nothing wrong with it. He checked the internet line and indeed I am receiving the full internet speed. His very own laptop connected to the Wi-Fi and received 5.7 Mbps just fine. The interesting thing is that previously when I had At&t FastAccess Dsl with the 6.0 Mbps service as well, I would receive via Wi-Fi on this very laptop 5.2 Mbps however, in that case that is what every other device would receive as well because the internet speed coming into the home was about 5.6 Mbps max because of the Dsl tech. So all in all, what could be going on with my computer that is causing it to max out a full Megabit lower than all the other devices connecting to the same network??? I am running Windows XP with all the updates, no issues with the computer such as Viruses or AdWare either. P.S. I've used both Speedtest.net and Speakeasy broadband tests on all the laptops tested (even the iPhone and iPod Touch).
Oct 03, 2009 | E-Machines M2352 Notebook
See all E-Machines M2352 Notebook Questions
E-Machines M2352 Notebook Logo
49 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
