Question about Kenmore Elite 45986 Front Load Washer
Has a bad oder - water seems to sit in the tubular connection. What do I do to remove the smell?
  • mimi451 Oct 08, 2009
    The problem we are having is that the water is not completely being removed and it sits in the bottom of the machine and creating a stagnate, sewer smell.
    Any ideas?
    Problem Solver:
  • 5 Answers
Their is a cleaning kit called affresh available at most lowes stores in the appliance department that if u follow the directions will help alleviate the problem. these units r sealed sysems and after u shut the door they do not breath, it would be like never cleaning your shower after using it and just shutting the door. follow the directions and make sure u repeat it about once a month. it might take two or three tries the first time to knock odour down, but it will come back without regular maint.
Posted on Oct 08, 2009
  • jim barnes Oct 08, 2009
    their is some water sitting in the bottom of all these machines and if the environment it sits in is already musky it sours quite easily, try running the cleaning cycle to remove old buildup fron the basin first.
How do I clean smokey smell from AC vents of 2010 Prius?
Remove the AC/heater blower motor and clean out the mouse nest or leaves you will find in the housing.
Jul 19, 2012 | Cars & Trucks
Getting Rid of Disposer Smell
Remove and clean trap underneath sink.
Then flush disposal and tubular drain with hydrogen peroxide
May 23, 2012 | Electrical Supplies
Will not drain...but is turning....i tried to reset by pushing the red button and did nothing...i took the L wrench and turned it from the bottom and still nothing...sink is full of water too..what can i...
1) If disposal will not drain: Clean the tubular drain under sink.
Remove 2 nuts on p-trap, and trap falls loose, then remove tailpiece on side of disposal, hand rag over opening to direct water downward, turn on water, turn on disposal and see if disposal empties, clean p-trap, and then reassemble tubular drain.
2) If disposal will not drain and will not run: Clean tubular drain, check for power to disposal.
If disposal is getting power and will not run, and reset button is not tripped out, and cutter disk rotates freely, then disposal is bad.
I wrote ez disposal replacement steps that include tips for tubular drain.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 21, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The washer smells. I have run 3 Affresh tablets and a bleach cycle and have left the washer open all night. However, the washer still smells. What else do I need to do?
Hi, I once experienced a similar, bad smell problem with my washer. What it turned out to be was a small sock being stuck in the water discharge pipe. This stuck sock eventually began to mold and subsequently smell. Once removed, my problem went away. Also, you can try running your machine with vinager or bleach with NO clothes. This weill remove any lingering oder. Hope this helps. Good Luck!
Jan 10, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
The product hisses all the time and emits and strange oder - is there a solution?
Sounds like a bad belt and it is burning as the motor tries to turn the brush. Does it smell like burning rubber?
Dec 04, 2010 | Vacuums
We own this air conditioner and it is one year old. It is working find, however, when running in the air conditioning mode it omits a musty oder. Where I am allergic to mold , I am concerned especially...
The problem is common. It is not a mold spore situation, rather it is a moisture laden problem of parts and dust that create an oder when allowed to warm and stay moist. A spray bottle with 1/2 clorine bleach and 1/2 water sprayed onto the inner components will remove the oder, but as the unit sits idle from time to time, the oder will reappear.
Aug 10, 2010 | Amcor AF9000E Portable Air Conditioner
Gas smell inside maytag neptune gas dryer
gas has an oderant added to it and in your dryer in the cool down it allows most of the gas to be removed.if you smell gas when the dryer is off and empty, then you have a gas leak.thanks karl
Jan 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Washer still has lots of water in it at the end of the spin cycle. Also, we notice bad oder each time the washer is used. Are these related? How do I fix this problem?
The most common problem is the water pump is malfunctioning and not allowing the water to drain all the way out, if the machine sits over a week the water turns sour and smells bad. so check that the pump is not plugged up and check that the pipe from the pump is not plugged up. if hose is not plugged up and the belt on the pump is tightened up it could still be a bad water pump so I suggest you replace it. Also with a water hose push water threw the drain pipe in the wall to see if the pipe is plugged, it should take full water hose pressure without a problem, if it backs up then you have a plugged drain pipe. remove the drain pipe form the hole in the wall and push hose onto the water hose put washer on spin and have other end off the hose bib, watch the water flow as it pumps water out of the spin cycle if the water does not come out fast than you have a bad pump or a bad water pump belt. since it won't drain all the way this will cause the water to smell sour.
Dec 13, 2009 | GE Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
78 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
