Question about Remington Electric Chain Saw
Remington 12 inch electric saw, chain came off, cannot find manual to put it back on. I am 73 and need to put the chain back on to cut up the pallets for heat. I need to put it on the right way. A picture would be good, just have to know direction of teeth. thanks, nancy
    President:
  • 2,220 Answers
remington 12 inch electric saw, chain came off, - c2d7ab8.gif Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Posted on Oct 08, 2009
  • 546 Answers
Wear gloves when handling chain,teeth are sharp .the 'bar that the chain rides on is retained by two nuts attached to studs protruding from the case.on the other side of the bar is the adjustment screw.loosen nuts,turn screw counter-clockwise to 'shorten'bar to allow chain to be re-installed on bar. with tip of bar lifted,re-adjust chain. you should only be able to pull chain off bar about a half a tooth at center span.while holding tip up,tighten retaining nuts,check that chain runs smoothly by hand,re-adjust as necessary.curved or sharp end of teeth should face towards the direction of rotation.if chain is stretched[tight at one position,loose at another] or broken it must be replaced.
Remington manuals
For an electric saw, just add oil to the chain oiler, plug it in, and cut away. Do not put any body parts in contact with any of the moving parts of the saw.
Sep 02, 2014 | Remington 10" Electric Pole Saw Chain...
Need to find parts
Remington is no longer in production, many parts are NLA Elley.
Start here with the IPB:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
If NLA above try the part number here:
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
If this provides nothing eBay is the most likely source.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 21, 2010 | Remington 16" Electric Chain Saw
I'm a girl. remington electric chain saw not cutting. chain seems loose, was out of lubricating fluid, added more, still won't cut. how can i fix it? or do i need to sharpen it and how?
Yes you need to "have" the blade sharpened. I emphasize "have" for if you've never done one it is virtually impossible for me to insruct you from here. It doesn't cost much to get them sharpened. Also make sure the guy tells you what direction to put the chain back on. Thank you, Dana
Mar 26, 2010 | Remington Electric Chain Saw
Chain replacement.
Input "M12510US" in the model number here (if not your saw the procedure should be similar):
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
See pages 7 through 9, for use as a guide.
HTH
Lou
Are you aware RemingtonPower is no longer in production? Replacement parts are becoming difficult to find.
Jan 23, 2010 | Remington Electric Chain Saw
Remove range cover on remington chainsaw Model LD4018Aw
this web site has partsbreak downs.................http://www.masterparts.net/ hope this hepls,let me know
Jun 01, 2009 | Remington Electric Chain Saw
Replancement bar for 16 inch remington chain saw
The bar is the piece of metal that the chain goes around. This link has lots of info on your saw http://www.remingtonchainsaw.com/chainsaw.html
Mar 31, 2009 | Remington Electric Chain Saw
Chain comess off bar ever7ytime u cut
put the chain on and adjust the chain tension so that it is a little snugger than it has been. that should solve your problem. if it doesn't it may be time to replace the chain bar.
Jan 29, 2009 | Remington Electric Chain Saw
Remington 16 in. electric chain saw
Go to www.masterparts.net Remington chain saws are listed by bar length and model number. There is a parts list with each saw.
Oct 27, 2008 | Remington Electric Chain Saw
Remington Electric Chain Saw  Logo
454 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
