Question about Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi
How to remove a jammed nail in a porter cable fr350 nail gun
  • 37 Answers
Here is a link to the manual for your nail gun. Refer to page 11 of the manual for removing a jammed nail. To get the manual, go to the link, click on the "Manual" tab and the in the gray box, click on the name "FR350A Manual". The link is:
http://www.tylertool.com/porfrrounhea.html
Hope this helps. If it does, please leave feedback.
Posted on Oct 08, 2009
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
FR350 won't shoot nails
Normally I would say you aren't using enough air pressure because somewhere around 80psi (every tool is different) will not be enough to fully retract the driver. At 110 you are fine so that is not the case. I doubt it is broken because a broken driver will still retract unless it broke near the piston. My guess is it needs the o-rings replaced but you can pull the top head and pull the driver out first to make sure. Parts and breakdowns can be found here as DeWalt owns Porter Cable.
PC FR350 diagram
Aug 19, 2012 | Porter Cable Air Tools & Compressors
I have a porter cable fr 350 an it says to use 22 degree nails it i have always used 21 degree nails in it will this hurt the gun
There are many different brands of nails sold for your gun. Nail companies try to sell nails to fit as many different guns as possible in one box(will range a few degrees). I have found that the stated angle is not always exact. To determin the best nail for your gun, place a strip of nails on the outside of the rails with top of the strip of nails (nail heads) aligned with rails. Now slide the nails forware to the centerline of the path of the driver. If a perfect fit, the first nail will align with the rails and the path of the driver. Note if the bottom of the nail is ahead of the nail head. If this is the case the driver will not hit squarely on the head of the nail. If the head is in line with the driver but the shaft of the nail angles back toward the rails, the nail may jam against the nose. Use your best judgement when buying nails. If you have not had a jam, keep using the nails, however test the nail as described above for good fit. Good luck
Sep 06, 2011 | Porter Cable 60074 Overhaul Kit For FR350...
Jammed nail gun fc350a
Nail guns will jam when driving nails thru very hard wood, solid objects, allowing the gun to double fire hitting the first nail or using the wrong nails(amoung some of the reasons, you get the idea that jamming is common) . There is no special tool to help in case of jam. You must be creative. I use an old driver shaft from nailer that easily fits into the nose of the gun (you can grind a piece of allen wrench to fit into nose and allow space for the stuck nail). The metel that you use must be very hard and strike with heavy copper or brass hammer (caution, steel hammer may splinter metal, use protective gear ). You will need to strike very hard to remove some stuck nails. If first or second strike results in no movement of driver, remove the head and cylinder of the nailer and place the body of the gun squarely on piece of plywood over concete floor (this will protect the head of the nailer from being damaged). Worst case, you will need to remove the rails. Good luck.
Jun 25, 2011 | Porter Cable Factory-Reconditioned...
FR350 nailer ram does not fully retract. Lubed ram and it worked most of the time for the next clip of nails. Now it is back where it started, retracting about two thirds of the way, not enough to get...
Did you rebuild the tool? If not remove all the nails and unplug air, BUMP nose on piece of wood and does driver fall down? If so the pistion o ring needs to be replaced. Also if this is not the case look for a jammed nail in the magazine/nose area. Next check for a bent driver blade. All the above could cause your problem
Jun 06, 2011 | Porter Cable 60074 Overhaul Kit For FR350...
Hello i have a mildly used FR350 round head framing nailer. the problem is that it will shoot two or three nails then jam up? thanks todd
This gun is very reliable unless tip is broken or miss-shaped and or wrong nails are being used. Depending on model # could be clip head or full round. For best results do not use generic nails because they are not the exact angle required. Place a strip of nails on outside of rails with nail-heads aligned with edge of rails. The first nail should align with path of the driver (place a straight edge alighed with path of driver). Most generic nails do not align correctly. Good luck
Feb 28, 2011 | Porter Cable Air Tools & Compressors
Porter Cable FR350 Round Head Framing Nailer not firing
check and make sure your compressor is at the right psi. 120psi. is there any nails stuck in it. there may also be a problem with the seals.
Mar 08, 2010 | Garden
I have an FR350 PC nailer and I have a nail jamed in the noise piece between the housing and the driver. Do you have a suggestion?
Remove with a pair of plyers. If that does not work use a nail punch and drive the drive pin back into the gun until the nail comes free.
Feb 01, 2010 | Porter Cable Cable No. FC350A Clipped Head...
Depth of nails
Sounds Like it's time for a Rebuild. On the Other Hand the tool may not have a Steady regulated pressure setting??
After further research I came up with a Contact Number for You for Porter-Cable for Service Centers 888-848-5175, I'm sure They can Help You Troubleshoot this Nailer more In-depth...
IF, You can't get any satisfaction with the Service Center you come up with, get back in touch with me, and give me an Area of the Country your In, and perhaps I can get you to a Better solution. I reviewed your Model Parts Schematic and seen Several Parts that could be the Culprits. But at this Point I strongly feel That Porter-Cable Service Center would be Your BEST alternative. Good Luck!!
Mar 26, 2009 | Porter Cable Cable No. FR350A Rnd Head...
Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi Logo
903 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim London
Jim London
Ed Mac
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
