SOURCE: I have a 1990 Dodge
the numbers are 12, 41, 55
12- direct batttery inut to controller disconnected within last 50 ingnition key-on cycles
41- alternator field circuit- an open or shrted condition detected in the alternator control circuit.
55- final code - indicates the end of the scan codes
I've replaced the alternator and checked all the wiring still can't find the solution. I've posted to find out if the alternator control circuit can be repaired.
SOURCE: 2001 Dodge Durango will start from a jump.
replace the battery, on a dodge when battery is weak the idle air control solenoid tries to search for the right position. and will keep stalling sometimes wont stay running.
SOURCE: AIR STOPS BLOWING OUT OF VENTS WHEN ACCELERATING
On the side of the intake there is a one way check valve in a vacuum line to the vent controls. Replace it
SOURCE: 1996 Dodge Ram runs and dies
Google for Refurbished PCM "brain" and call the site from Florida. My Durango kept stalling wihtout warning and I replaced the PCM for < $300.00 and no problems since.
SOURCE: where is the bank 1 O2 sensor on a 318 v8 dodge
the o2 sensor is on the exaust manifold on the left side of the vehicle where the flange of the manifold meets the resonator right befor the catalayic convertor
