Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi tv model ms-55513
Power button keeps blinking, tv will not come on.
  • Anonymous Dec 01, 2008
    blinking light wont turn on
  • Anonymous Dec 07, 2008
    green light near power on button blinks quickly and tv will not respond to anything?
  • 137 Answers
It can be in stanby, lightning damage or it could be childlock, only original remote will put it on.
Posted on Dec 24, 2007
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
Dec 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 blinking light
Try first unplugging power cord for one hour.
Oct 06, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 won't power on.
there is an electronic problem inside the tv you shoud go to an authorized service because the power supply to this tv it is in protect mode somehthing hapened inside and need to be repair
Dec 11, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I have a mitsubishi 1080 projection tv. I wont turn on, the green light just keeps blinking.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
Dec 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Power button is blinking but tv does not work
when my tv does thiss I unplug it, replug it and it works.
Nov 16, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
Jun 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsu HDTV 55 inch model #WS55613 power failure problem
Four bad 1000mf/25v capacitors in DM module = common repair
for qualified Mits tech.........................T.
Nov 03, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws 55513 rear projection HDTV
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT
Aug 10, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
