Question about Microsoft Xbox 360 Console
I had brough an xbox 360 on the 6/12/08 and it is not playing the discs and you have to hold the connection lead in. I would like this problem to be sorted. mrs.d.crocker (serial Number is: 854093684205)
  • 715 Answers
X-BOX .COM WILL FIX IT FOR $ 99.00
Posted on Oct 08, 2009
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
Tip
Xbox help for "Can read CD but NOT DVD."
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
on Feb 15, 2010 | Video Game Consoles & Games
Xbox reads and plays movies but not games
This is a problem occurring in all the play station 3 consoles....... this is mainly because of the poor quality of the disc,.....as a result it leads to the damage of ur lens..............use good original discs........the heating effect is due to the long usage of pirated discs ...
check your lens if its working good then better download this Repair Guide for further information .........
CLICK HERE to download
Dec 09, 2010 | Microsoft Xbox 360 Console
Some of my games won't play in my xbox 360 but will in other systems.
This is a problem occurring in all the xbox 360 consoles....... this is mainly because of the poor quality of the disc.....as a result it leads to the damage of ur xbox lens..............use good original discs........the heating effect is due to the long usage of pirated discs ...
click here to download
Dec 08, 2010 | Microsoft Xbox 360 Console
Xbox wont read any disc
first you need a broken cd then your xbox raed that but it cant en then take a xbox game thats not broken hi is raeding that an then you can play gamertag ChillingCarrion
Aug 31, 2010 | Microsoft Xbox 360 Console
Xbox360 will play cds but no games, says onscreen
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
Sometimes like you mention it will still play CD's though.
Feb 13, 2010 | Microsoft Xbox 360 Console
My fable 2 disc wont work and its only been play twice HELP!!
Try your Fable 2 disc on a friend's console that you know works and see if it plays. This would rule out the possibility of it being your Xbox for sure. Then it would have to be the game. If you didn't buy it too long ago, look inside the game package and find Fable 2's tech support number or go to their website and try to get a hold of them. Good Luck!
Jan 05, 2010 | Microsoft Xbox 360 Console
Xbox will will not play any games or DVD's.
try putting the game disc into your game console and close the lid with your hand without pressing the close lid button. hold the disc tray with your hand and turn off the game console. Turn on the game console. If problem still persists try cleaning the xbox with a blower or a vaccum. Pm me if problem still continues. Thank you .
Aug 07, 2009 | Microsoft Xbox 360 Console
When I play Halo 3 it turns green. and other games get blurry in background, I just bought Fable 2 and I cant play that because it is too blurry, its not a scratched disc, and I rmoved dust in my 360
you may have a faulty AV lead, from xbox to TV.
or the graphics chip is failing, if you have a composite lead ( red-white-yellow-green-blue ) check that the switch is set to hdmi correctly. this is on the side of the oval connector from xbox outlet to tv lead.
try tuning into a different tv channel, check that the lead isn,t broken internally.
If this does not work, assume that the GPU Or graphics chip has come loose, and obtain A RROD repair kit.
Mike @ Compurepair.
Jun 12, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
22 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
