Question about Sharp XLMP131 Shelf System
PROTECT ANY TIME I PUT ON MY STEREO IT LOCKS UP AND PROTECT COMES ON THE SCREEN.CAN YOU HELP ME?
  • maynard1980 May 23, 2008
    same thing with mine. protect comes on screen when i turn on the stereo and i cant do anything!!!
    Problem Solver:
  • 18 Answers
Or this may be a high Impedance problem..........if you have wire going to your speakers check for good connection-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Posted on Jun 08, 2009
    Problem Solver:
  • 6 Answers
I think your output ic is damaged...try removing it then power up,if it is cleared replace
Posted on Jan 23, 2008
    Problem Solver:
  • 6 Answers
Wow! What will they think of next? This is the first time I've heard of a stereo with a protect on it. Well look through the manual and see if it saids something about the protect feature. If not, contact customer service and see if there's a code you could input into the stereo to unlock it.
Posted on Dec 25, 2007
Write protect
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 20, 2014 | GE A1255 Digital Camera
My sharp Stereo is stuck in '' protect'' mode
Protect mode is not something that a reset will fix. Basically it indicates that there is a problem with the final output stage of the amplifier. Normally this indicates that the output transistors are defective. In most boomboxes, the amplifier is a single IC. If you can post the model number, I can provide you with the required part and cost.
Thanks,
Dan
Mar 25, 2009 | Sharp Audio Players & Recorders
My stereo system blinks PROTECT on the screen
one of the out put tran is short ,
there normaly 4 to 8 of them
screw to a big heat sink ,
easy to get to.
check with a volt meter
then google the part
they cost 8.00-12.00
Mar 17, 2009 | Sony MHC-EC98Pi Shelf System
It says protect on the front screen
An amplifier goes into protect when it detects a load with too low an impedance. If it displays protect with no speakers connected at all, the amplifier is damaged. If not, reconnect speakers one at a time (while the amp is off!) to determine the cause of the fault.
It may be as simple as a single strand of copper wire shorting between the positive and negative terminals of a connection.
Nov 29, 2008 | Onkyo GX-D90 Main / Stereo Speaker
My stereo
Disconnect your speaker boxes. If the "protect" error goes, then the speakers or wires may be at fault. If the error remains, most likely the audio output IC is blown.
Aug 31, 2008 | Sharp CD-BA200 CD Shelf System
Protect mode
i try to turn the stereo on a message saying "protect" comes up and then it shuts off
Apr 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Protect
The audio amplifier of your device are damaged and you need to replace him.Good luck
Nov 15, 2007 | JVC HX-C6 Shelf System
Can't do anything - LCD screen says "PROTECT"
It may be that there is a problem with a fuse inside the stereo. It may say protect because the fuse has broken a connection that allows it to turn on. If the protect goe sup it is trying to help save the stereo from cooking its self, and give you a chance to get it fixed. If that is not the problem then it may be easier to just buy a new one, because a fix may be expensive if you don't have any warranties.
Jul 30, 2007 | Teac MCD-85 CD Shelf System
122 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
