Question about HP DeskJet 722c InkJet Printer
My HP 722C printer will not print. When print button is pushed both the print button an out of oaoer light flask and play a small tune. When I open the top cover the print cartridge tray does not come out to the center. Can this be fixed?
  • 21 Answers
SOURCE: Error message "cover door is open or printer cartridge is missing"
Try to find the latch in the cover that presses a switch to indicate it is closed it is usually a small stick projection at the sides of the cover. Replace the cartridge it should fit snuggly then try it again.
Posted on May 31, 2008
  • 47 Answers
SOURCE: attention light flashing- says replace black cartridge
Try reset the printer. Turn off powerswitch, press gobutton, turn on powerswitch while pressing gobutton. hold approx 15sec and release the button. The printer will reboot. Clean the cartridge contacts and HV pins in printer.
Posted on Nov 22, 2008
SOURCE: top cover open error when printing
I had the same problem and fixed it by sticking the end of a pen (the writing part) in the hole on the right side when you open the top cover.
In other words if you open the top cover and look on the top cover you will see a tab that goes into a hole(the hole is next to the picture of the print cartridges). There is a hole with switch/tab(I don't know the proper terminology) on it that is activated when you close the top cover. If you stick the end of a pen in that hole it should activate something and the print cartridges will start to make noise and move around. You can then close the cover and it should close all the way.
You can then try to print a test page.
Good Luck
Posted on Dec 29, 2008
  • 4 Answers
SOURCE: hp 812c cartridge cradle is stuck on the right, not moving to the
unplug the printer and try to move carriage by hand, if it does not move, the carriage mechanism is broken, if it does move, plug the unit back in, if same error occurrs, it is an issue with the printer carriage mech.
Posted on Feb 27, 2009
SOURCE: My printer made a weird noise and now says
Issue The error ' Open Door, Clear Carriage Jam, and then Press Enter ' displays on the product. The following symptoms might also accompany this error:
* The product will not print. * Printing stops unexpectedly. * The carriage does not move.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. Solution one: Turn the All-in-One off and on again
1. Press the Power button ( ) to turn off the product. 2. Press the Power button ( ) to turn the product on again.
* If these steps resolved the issue , you do not need to continue troubleshooting. * If the issue persists , continue to the next solution.
Solution two: Clear any paper jam A carriage jam might follow a paper jam. Follow these steps to check for and remove any jammed paper. Step one: Check for and remove any loose paper from the input tray Remove any loose paper from the input tray, the output tray, and the automatic document feeder (ADF). CAUTION: Do not remove jammed paper at this stage. Step two: Clear a paper jam from the rear access door WARNING: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the printer slowly and gently. Avoid touching the internal components of the printer.
1. Disconnect the power cord from the back of the printer. 2. Remove the back door and remove as much jammed paper as possible.
3.Replace the back door and open the carriage access door. If there is paper visible that cannot be removed through the back door, gently pull it out from the front.
4. Reconnect the power cord and close the printer.
Solution three: Make sure that the carriage moves freely
1. With the product turned on, open the cartridge access door. The carriage might try to move into the access area. If so, allow it to move to that position. 2. Without turning off the product, unplug the power cord from the back of the product. WARNING: You must disconnect the power cord to move parts by hand without the risk of an electrical shock. 3. Look in through either the cartridge access door or the output paper tray to make sure that the cartridges are secure in the carriage and not loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving. 4. Make sure the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You might have to reach through the output paper tray to access the carriage. 5. Close the cartridge access door and reconnect the power cord to the product. 6. Press the Power button ( ) to turn on the product.
Solution four: Remove and reinsert the print cartridges Incorrect installation of the print cartridges can cause the product to show a false carriage jam. Follow these steps to remove, and then reinstall the print cartridges. Step one: Remove the print cartridges
1. Press the Power button ( ) to turn off the product. 2. Open the front of the product to access the carriage. The carriage moves to the center of the product.
3. Unlatch the two print cartridge latches, and then raise the latches. 4. Remove the print cartridges.
Step two: Reinsert the print cartridges
1. One at a time, hold a print cartridge with the printed label up, and then slide the print cartridge into its slot. Repeat this step for the other print cartridge.
# NOTE: Insert the black print cartridge into the slot with the gray latch, and insert the color cartridge into the slot with the blue latch. # Grasp the end of the latch on the cartridge slot with your thumb, and then pull the end of the latch toward you. While holding the latch, press down on the top of the latch until it stops, and then release the end of the latch so that it catches under the tabs. CAUTION: To avoid damaging the product, do not force the latches into place.
3. Close the product cover. A message displays on the control panel to align the print cartridges. 4. Press the Enter button to begin the cartridge alignment. Two pages print. Follow the instructions printed on the second page to complete the alignment. 5. Try the print job again.
Posted on Jul 08, 2009
Reset an hp 722c printer
To reset your printer, unplug from wall and computer. Wait 1 minute. Done. That won't fix your problem. If it prints fine off word processor, the printer is fine. Need some setup for labels.
Oct 13, 2014 | HP DeskJet 722c InkJet Printer
I want to use my HP 722c wireless
You need to get yourself a wireless print server to connect to your printer. This will allow your printer to connect to the wireless network and print over wifi.
Here's one I found on Amazon I think will do what you need:
Belkin 802 11g Wireless USB Print Server
Mar 26, 2014 | HP DeskJet 722c InkJet Printer
Everything from laptop to printer seems to be fine. when I click 'print' in the print box, i get an error in print que and the printer cartridge light flashes on front of printer. have tried new...
Try doing a self test by holding the paper feed button until the green light flashes. If it prints a test page then you should try a different printer cable. You can also clean the contact points on the cartridge (looks like gold dots) by using nail polish remover or surgical spirits.
Apr 13, 2010 | HP DeskJet 722c InkJet Printer
I have just replaced the color ink cartdrige in my HP Deskjet 722c printer and I tried to print a color picture in bond paper and it was a total mess
A new ink needs a little cleaning before using. Just dab lightly on a damp paper towel and look for a inch log stripe of each color on the towel. If all colors are not there it won't print very well and you should return the cartridge. Some have reported no yellow in their new cartridges.
Jan 08, 2010 | HP DeskJet 722c InkJet Printer
Not printing on windows 98
did you try to reinstall the driver?
It is here : http://www.nodevice.com/driver/DeskJet_720C_722C/get30251.html
or
http://www.bioticaindia.com/deskjet-722c.html
Dec 12, 2009 | HP Office Equipment & Supplies
Printer sometimes will not print must push paper button several times.
Hello sir; Try to clean up paper pick up roller with alcohal, otherwise , you have to replace paper pick up roller.
Nov 06, 2009 | HP DeskJet 722c InkJet Printer
Tiny print
I have a two printers, a Dell and a HP, both had the same small printing problem. I am not a computer wiz by no means, but I went into the printer settings and switched to "Factory Settings" for both machines and it fixed the problem. Hope this works for you.
Oct 17, 2008 | HP DeskJet 722c InkJet Printer
Banner printing on HP DeskJet 722c InkJet Printer
The problem with your printer is probably if you are using Windows XP it will not print banners from there. I downloaded drivers too and found if I went to a printer with Windows 98 and put in my software program the banner will print out. Hope this works for you. I had to find it thru trial and error.
Verron
Mar 14, 2008 | HP DeskJet 722c InkJet Printer
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
Problem with ink cartridge
Take a look at www.fixyourownprunter,com Also Tech support at HP
Jul 02, 2007 | HP DeskJet 722c InkJet Printer
HP DeskJet 722c InkJet Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
