Question about Kenmore Refrigerators
Refrigerator is leaking on the ground - Kenmore Refrigerators
  • 111 Answers
Assuming you are talking about water leaking, if it has a drip pan to catch condensation, it may be full and overflowing or missing a drip pan allowing water to fall to floor. If it has an icemaker and/or cold water dispensor, it could be a connection leak.
Posted on Oct 08, 2009
What could be causing leaking water from bottom of refrigerator
If it has an ice maker, it could be leaking behind the panel that covers the evaporator coil making its way to the ground. the water feed into the ice machine should not be pushed back...sometimes when they are manufactured, this gets overlooked.
Feb 21, 2015 | Samsung Refrigerators
Will not start p2045 p2197 p0190 p2247 p2245 p2248 p2249 p2518 comes up
code p2045 refers to reductant temperature sensor--high input==causes --wiring faulty sensor
code p2197 refers to heated oxygen sensor(HO2S)1 bank 2-- signal stuck lean===causes HO2S---fuel pressure---injectors---intake leak
also refers to oxygen sensor (O2s)1 bank 2 -signal stuck lean===causes--O2S--fuel pressure---injectors---intake leak
also refers to heated oxygen sensor (HO2S) 1 bank 2--implausible signal===causes wiring---short to ground--short to positive--HO2S---ECM
code po190 refers to fuel rail pressure (FRP) sensor-circuit malfunction===causes --wiring ---fuel rail pressure sensor---ECM
code p2247 refers to heated oxygen sensor (HO2s) 1 bank 1 reference voltage--open circuit===causes--wiring ---ho2s
also refers to o2s 1 bank 2 reference voltage ---open circuit===causes wiring---o2s
also refers to HO2S 1 bank 2 ---no signal===causes wiring--ho2s---ECM
code p2245 refers to HO2S 1 bank 1 --reference voltage --circuit low===causes--wiring short to ground--ho2s also refers to o2s 1 bank 1 circuit low===causes wiring short to ground--o2s
code p2248 refers to the ho2s I bank --performance problem===causes --wiring--ho2s
code p2249 has the same causes short to ground---ho2s and o2s
code p2518 refers to a/c refrigerant pressure sensor B ---circuit high===causes wiring short to positive--a/c refrigerant pressure sensor.
so after all that replace all the ho2s and o2s sensors using the correct tools so that the wiring is not damaged and check the wiring back to the ECM for burns and rub marks.
Dec 30, 2013 | Cars & Trucks
Water leaking in at the bottom of the freezer and the draw jamming with ice. This is a frost free refrigerator and freezer.
Sometimes a solid ground wire
wrap around the defrost heater and the other end stuck in drain hole has helped for me. Avoid letting the wire or whatever to touch the plastic side of the hole.
Aug 01, 2011 | LG LRBN22514ST Bottom Freezer Refrigerator
The compressor is hot.fan is working,but freezer and fridge arent getting cold.could it be a leak in the system?
Hello, Thank You for using FixYa. I will be helping you today.Yes it can also be a bad relay on the compressor.But most times if the freon leaks out the compressor runs cold.Usually hot when grounded failed compressor or failed relay.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Refrigerators
The freeze of my Maytag plus refrigerator is not working
You need to check the Condenser coils, these are copper coils of tubing usually located on the back of the unit near the ground. They need to be free of all dust and grease to work at maximum efficiencyand it is recommended to clean them every 6 to 10 months.
If that doesn't solve the problem then there may be a refrigerant leak. In order to legally put reclaim, recharge, or test refrigerants you need a special certification2_bing.gif from the EPA. If you need to do so I recommend you call in a certified technician.
Mar 30, 2010 | Refrigerators
I have a AEG S75380 ..similar to I would like to
The way to determine whether it's the thermostat or a refrigerant problem is to take note of when it shuts off. If you can hear the compressor running all the time then the thermostat is fine. If the compressor shuts off before the refrigerator gets cold then it may be a thermostat problem.
Before assuming it's a 'gas' or refrigerant leak I suggest you check the condenser coils, these are copper coils of tubing usually located on the back of the unit near the ground. They need to be free of all dust and grease to work at maximum efficiency and it is recommended to clean them every 6 to 10 months. If that doesn't solve the problem then there may be a refrigerant leak. In order to legally put reclaim, recharge, or test refrigerants you need a special certification2_bing.gif from the EPA. If you need to do so I recommend you call in a certified technician.
Mar 25, 2010 | AEG S70408KG Bottom Freezer Refrigerator
My Rm2652 Refrigerator in my Rv just quit cooling. The electric element checks good and heats as well as on gass. I did not smell any amonia odor from a leak and have not taken it out and turned it upside...
You need to have 12 volt supplied at all times to make it work
Check to be sure you have a good 12 + and a good ground.
Lots of times the coolant leaks without you smelling anything Slowly over time
Mar 06, 2010 | Dometic RM2652 Refrigerator
I was vacumming the coils under my whilpool side by side when I believe I heard a faint whistle along with a odorless thin white smoke that stayed low to the ground. The compressor is hot to the touch, yet...
yes it sound like you did puncture the refrigerant line to your unit, if you have a sorae refrigerator I would proceide in relocating the stuff and call a service company out to repair the leak.
Dec 27, 2008 | Refrigerators
Refrigerators Logo
173 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
