Question about Garden
Starting problem old gas has been replaced with fresh gas and the mower still does not start.
    Problem Solver:
  • 5 Answers
Pull the gas line of the carbureator and drain the line. Crank the mower for awhile to get all that bad gas out of the line and bowl, then re-install the line and continue to crank it over. That should work, otherwise, you may need some cleaning performed. One thing you can do once you get ready to start it with clean gas, remover air breather, take a small rag slightly soaked in gas and momentarilly hold it over the air intake of the carb when you crank it over. That usually gets it going and it might be fine after that. You just have to get that bad gas completely out of the system.
Posted on Oct 08, 2009
Wont start,pops, slow-low idle if at all.
Hello Donald,
Always make sure to disconnect the spark lead BEFORE handling mowers... in EVERY manner.
Simply turning the blade can start them (when they are feeling good).
The single biggest trouble with starting mowers is OLD, TIRED fuel.
If your gas is FRESH skip to the double asterisk ** below.
Disconnect the spark lead... remove the gas cap and turn the mower over and drain ALL the gas out of the tank into an old oil pan (to transfer to recycling container... for proper disposal... of course),
Re-connect the spark lead.
Put in your FRESH (newly purchased) gas... give the primer bulb (if equipped) a couple of pushes ... set the choke only until the engine coughs... the next crank it will start and run well...
**If it does not check for splits or cracks in the fuel lines... the fact that you are discussing idle at all gives your SPARK a clean bill of health.
Good luck and remember to watch out for that blade
Dec 29, 2015 | Garden
Lawn mower instructions why wont it work
check for spark at plug if spark at plug then squirt some starting starting fluid in carb see if will start it should run long enough to burn out starting fluid if does check for water in gas if is drain tank and carb bowl put in fresh gas not and repeat not old gas you were using strat lawn mower if still dosnt start rebuild carb and add and additive called seafoam to the gas this is good stuff follow instrution on bottle
Sep 02, 2014 | Garden
Won't start by using primer ,have to use starting fluid
could be a number if things, dirty carb, old gas, dirty coil contacts, low combustion chamber pressure, (bad rings), bad spark plug. First try replacing the spark plug and if it is old gas remove and replace with fresh. if that doesn't do it then the carb needs to be removed, cleaned and blown out thoroughly with an air compressor. reassemble and reinstall. next is to remove the recoil housing and clean the coil contacts. the coil is attached to the spark plug wire. remove and with some old gas or wd-40 and a wire brush, remove dirt and rust from contacts as well as magnet on the flywheel. be sure to leave the proper gap between the coil and flywheel when you replace the coil. If you can pull the recoil with your forefinger and thumb, chances are your machine is toast and needs a ring job. good luck
Aug 05, 2014 | Craftsman Front Propelled Rear Bag Lawn...
Starving for fuel runs fine on starting fluid
Make sure gas tank and gas line isn't plugged. Also, make sure the gas itself is good, might have water in it.
Apr 25, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Lawnmower starting problems
Clean or replace air filter. Fill oil, 30w. Clean & gap plug or replace.
Remove carb bowl from bottom of carb & clean. If gas is 30 days or more old, use fresh gas with Stabile.
Jun 19, 2013 | Garden
Model 911194 starting problems.
might be battery check to make sure cutters are not engauged and your start procedure is right
Feb 23, 2013 | Ariens Garden
TORO TIME CUTTER SS4235,NOT STARTING,NO ELECTRCAL POWER TO SWITCH
Check wiring for ground. Ensure battery is fully charged or replace. Replace spark plug. Clean or replace air filter. check oil level, all mowers have a low oil start cutoff. Bad gas? Flush out fuel tank by removing gas line, flush fresh gas thru. Reattach gas line, fill with fresh gas, always use Stabile in gas! Check fuel line for cracks and secure connection to carb. Battery should read 12.8 volts or higher. .
Aug 21, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Mower does not run B & S 5.5 HP
is the gas to old? more than 30days try fresh gas if the gas is fresh take the carb apart and clean it
Apr 25, 2012 | Garden
It will start but wont keep running
tip all the gas out.drain the carbie bowl.put fresh fuel in.drain the carbie bowl till fresh fuel comes thru,retry starting.put a new spark plug in
Jul 05, 2010 | Poulan "" Push Mower
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
