Question about HP Photosmart 3210 Printer
HP Photosmart 3210 - yellow seems to be clogged. Just installed new cartridge with no success fixing the problem. Is there a good way to unclog the ink delivery system in this printer>
  • 11,896 Answers
You can purchase a cleaning kit or use rubbing alcohol and cotton swab and clean the heads and the contacts, and make sure all ink is gone and there is no buildup.
Posted on Oct 08, 2009
Yellewo does not print
Must replace the nozzle/ cartridge carriage as the nozzle for yellow is most likely clogged
Aug 31, 2014 | HP LaserJet 2840 All-In-One Printer
My HP Photosmart 3210 Printer does not Print Red.
WELL IT'S 5 DEC 2012, THIS HP 3210 QUIT MAGENTA'S.
WENT TO TOOLS TO CHECK LEVELS, NO YELLOW, GOT NEW CARTRIDGE, TEST SHOWED NO MAGENTA'S. REMOVED RIGHT SIDE COVER (GENTLY) AND REMOVED ALL TEN CABLES AND REINSERTED CAREFULLY. TESTED AGAIN, AND HAD LINES ONLY ON BOTH LIGHT AND DARK MAGENTA'S,
RAN CLEAN HEADS, SIX TIMES AND ALIGN PRINTER ONCE.
PICTURE GOT BETTER AND BETTER FINAL TEST DIAGNOSTIC PAGE PERFECT ALL SOLIDS. GOOD LUCK KEEP GOING
Jun 08, 2012 | HP Photosmart 3210 Printer
The plastic hinge on the cover of my HP 3210 printer cover is broken and a nearby electrical connector has been disconnected. can you fix the problem or suggest someone who can.
Me 2 I was changing a the yellow cartridge and try to close the lid and POW the hinge on the right side broke. I got the printer opened and had to disconnect three ribbon cables the 3.5 mm jack and one 6 pin connector plug.
Apr 28, 2010 | HP Photosmart 3210 Printer
Photosmart 3210 bought Dubai need to change region Spain
Hello Friend
You can change region settings of your hp 3210 printer by changing your language preferences.Just select the language of your region and it will be fine.
Thanks,
Viju
Apr 03, 2010 | HP Office Equipment & Supplies
I get an error message "Ink system has failed",,what is this..I have replaced all cartridges, and still no good it then says carriege jam..nothing seems to be in the way, etc
I can only guess the printhead may be clogged, and you may have two things to try:
1.- Run several (>10) cleaning cycles, hoping it will unclog the prinhthead
2.- Try with brand new cartridges
I don't know if it will work, but ink ages, and it might have dried in the cartridge and clog the printhead. Fortunately, HP builds the printhead into the cartridge, so replacing it is cheaper than with other manufacturers.
OR
  1. ress the On button to turn the all-in-one off.
  2. Unplug the power cord from the back of the all-in-one.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the all-in-one.
  6. Press the On button to turn ON.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
Nov 25, 2009 | HP Photosmart 3210 Printer
HP 812C will not print yellow but everything else is A-OK Repeated cleanings have NO effect. Cleaned contacts on printer where it connects to cartridge, no effect. HP 23 cartridge only has about 10 pages...
HTML clipboardHi,
It you haven´t used your printer for a while It sounds like the yellow has clogged up in the print head.
Although you have ink you need to print something regularly about every 10 days to keep the tiny jets open
otherwise it´s like trying to pass a camel through the eye of a needle.
So the inks may have clogged up?
The empty weights are 65g C6615A [No. 15] black and
90g C1823A color ink cartridge
anything over that... 1g = 1ml of unused ink.
So if you still have ink you can easily unclog it with a HTML clipboard Magic Inkjet Flush Kit (find it on Ebay)
Or you can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Aug 02, 2009 | HP DeskJet 812c InkJet Printer
Black Ink shows empty even after installing on HP Photosmart 3210
These cartridges are really only ik resovoirs for the printer. It does have an ink flow sensor, though. If the printer does not recognize the ink level, it is possible that you got a cart with a bad chip. I refill these alot, and all you can really do is check the chip on the cart and make sure nothing is on the contacts...otherwise replace. A good step would be to put the old cart in and see what happens...
Mar 10, 2009 | HP Photosmart 3210 All-In-One InkJet...
My HP Photosmart 3210 thinks the ink cartridge is still empty even though I have replaced it.
Very simple cartridge. Check the chip on the bottom to be sure that nothing is on the contacts. Try installing the old cart and see what happens. Fortunately, these are not very expensive. Install the old one, unless you ran it until it locked the printer out.
Mar 08, 2009 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
