Question about Vacuums
I have an Electrolux LE canister. It runs for about 2minutes then shuts off for about a minute , then turns on again and it keeps repeating this routine!!! It is driving me nuts. What part do I need to replace? Apparently it is over heating. Please help. Thank you.
  • 430 Answers
The LE has a thermal cutoff. If the bag is overfilled or a bag breaks and clogs the bag chamber the vac will over heat.
This also happens if the hose, wand or neck of the power head is obstructed. Try dropping a coin through the hose, look through the wand and inspect the neck of the head for blockage. If the hose is clogged , remove the rear filter and plug the hose in to blow out the obstruction.
If all these components are clear, you either have a defective motor or bad thermal sensor.
Parts will come from AERUS Electrolux only.
Posted on Oct 09, 2009
Testimonial: "I should have explained alittle further. THis Lux has been rigged up in the inside. It doesn't have a thermal switch or the clear tubes most of them"
  • Chemist1961 Oct 09, 2009
    Well then you need to clarify, an LE never had the tubes for the control valve and I don't recall it having the thermostat light, but it had a thermal shutoff in line in the wiring harness resting against the motor, which is how it would sense the overheat.
    An overfilled bag would eventually overheat the motor as well.
    So if it is symptomatically cycling on and off the thermal shut off may have gone bad... and your description of overheating applies..
    But If it cuts in and out intermitantly then you have bad wiring, likely in the cord , or an internal short or a badly worn set of carbon brushes...so is it intermitent or overheating???
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
I have a Electrolux canister model L-E (circa 1986). Won't turn on. I think the foot switch is broken inside. Was working fine - turned it off then would not turn on BUT foot switch sounded different,...
I have one of these LE models also. Yes, the on/off button is broken. I have had to replace it twice on mine. My local vacuum repair shop suggested NOT to use your foot to operate this switch, but just press it on or off with your fingers. That will help to keep it from breaking.
Jan 10, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
Dec 16, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Bag full switch is bad
I assume this is an Electrolux Canister with long narrow body and a dial control on top for adjusting the bag fill level.. Please confirm model and name on canister, as in LE, Ambassador, Renaissance, etc.
If this is a plastic bodied unit with 2 side bumpers the body opens like a **** shell after sliding the bumpers out the front. The normal cause is a failed control valve under the dial at the top center of the vac. The failed part can only be replaced, not serviced and can purchased through an AERUS Electrolux repair center. Please confirm and I can wa;lk you through the process if required
Dec 12, 2009 | Vacuums
My vacuum is constantly shutting itself off. When
It sounds like you have a blockage somewhere and the air is not passing over the motor to keep it cool. There is usually a thermostat mounted either on or near the motor. The blockage can be anywhere from the elbow ( the swivel part of your carpet sweeper if you have a canister vac) up thru the hose.If you have a canister vac, use a broom handle to push through the hose to clear the blockage. DO NOT ! use a coat hanger or anything that will cut or tare the hose. There are electrical wires in it that have 120 volts and causes quite a shock !
If you have an upright vac, start with the duct hose that comes from the part with the brush up to the hose and on to the main canister of the vac
If this does not work, take your vac to a reputable vac shop for repair. Hope this helps,
Joe
Nov 16, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Protection light
it might be the bag or the sensor inside the machine.
Jun 28, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux 2000 Mod# c151c
Turn the knob on top all the way to the right
Jul 04, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Lux Legacy shuting off by itself
i would say it is over heating but some times you cant tell because electrolux have a sensor so when the get hot the turn off till they gool down soo if you really like the vacuum get it look at by a vacuum repair man.
hope this helps
May 10, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Canister - Stops working after 1-2 minutes.
Electrolux Canister - Stops working after 1-2...
Our vac works for a short time, then shuts off and makes clicking noise as if trying to restart again. Works after cooling for a while but for another very short time. Your suggestion on fix would be greatly appreciated.
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure
I would advise that it could be a thermal switch or a regular switch that the thermal switch is over heating and needs replacement – there are small hoses in the door section that could have been pinched or kinked and it stopping the air flow from the vacuum – also check for a clogged or plugged vacuum hose, a full vacuum bag or a dirty vacuum filter. Check the thermal switch or reg switch or the hoses in the door. Or feel free to contact your local vacuum dealer in your area or in the yellow pages, or call the factory @ the phone number listed below:
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Don – The Vac Man
Apr 21, 2008 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
141 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
