Home | Philips | 55PP9401 55 in. Rear Projection Television | Bad color
Philips 55PP9401 55 in. Rear Projection Television
Problem for Philips 55PP9401 55 in. Rear Projection Television
Bad color
By lemack08 on Oct 08, 2009
bad color
Solution #1
posted on Oct 08, 2009
Not Rated)
Seritath
Rank: Wiz
Rating: 81%, 39 votes
Define it and I will be able to help you more.But if it is too much of one color go the the color balance on the tv options menu,which is usually accesed by pressing a button on the t.v. itself.Then use the two closest to it to go down to color balance and fix it.Hope it helped.
Was this helpful?
Yes
No
Popular Solutions for Philips 55PP9401 55 in. Rear
Questions and Unsolved Problems for Philips 55PP9401 55 in. Rear
Do you recommend Philips 55PP9401 55 in. Rear Projection Television?
Answer
Answer
it took a while to power on now there is no picture or sound
Answer
Hi, I've a Philips Projection TV PTV392, model 52LP50. The problem is that blue ace is down than... (More)
Answer
i have a 55pp9352 and the red went out of wack and its to far out to bring it back with the remot... (More)
Answer
my philips 60PP9202 converge multipoint lines will NOT line up when i try to adjust them!! please... (More)
Answer
my tv turns on then 9 clicks later it turns off,then the process repeats
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 55PP9401 55 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
