Wher is the heater/ ac blower motor located on kia sorento 2004
  • 25 Answers
Not sure about kia but most are under the passenger side dash
Posted on Oct 09, 2009
2003 kia sorento, a/c heater controls are not working
There are fuses inside the car and under the hood. Check owners manual and investigate possible fuse blown. Ac,blower motor, dash, ac clutch, ac relay, blower relay. Always disconnect battery when working with anything electrical. Saves headaches
Sep 24, 2012 | 2003 Kia Sorento
I have a 2004 Kia sorento EX, and am getting a squeaky sound from the blower whenever the fan is on. How do i replace this unit?
You might not need to replace it entirly, it may have something caught up on it or the bearing needs oiling that is all, but you can locate this unit behind the passenger kickpanel. You will need to take the glove compartment out, then you will see the blower box, just unscrew some screws and detach some wiring harness and you should be able to access the blower.
Jan 31, 2011 | 2004 Kia Sorento
Kia sorrento 2005 blower motor does not turn on
Check your any fuse related to your heat/cooling first before assuming other else. If fuse are ok, then your blower motor resistor relay is damaged, and needs replacement... You can located this item by taking out your passenger compartment unit glove out. There is a black relay that is connect on top your the fan blower, take this out and replace iwth a new one... Cost should be about anywhere between 80 to 120+. It costed me 97.00 at autozone. Took 2 days to order.
Jan 11, 2011 | 2004 Kia Sorento
My heat dosnt work
Not much information to go on here.Thermostat if your heat gauge isn't showing a warm engine. Coolant level too low. Blower motor or fan switch. Heater core. Heat/cold selector door not operating properly...
Feb 01, 2010 | 2004 Kia Sorento
Heater switch only works on high . What is the electronic board called?
you need to check if the fan switch is working right or the piece I think you need to check after that is the blower motor resistor
Jan 19, 2010 | 2004 Kia Sorento
Ac blower motor
HI. Your issue will be with the actual resistor switch that regulates the current flow. This switch is located within the control cluster(fan speed switch).
Replacing this switch will correct this issue.
Sep 09, 2009 | 2003 Kia Sorento
2005 Kia Sorento only blows hot and cold air on high. Is it a blower motor resistor and if it is where is it located?
If the blower moter only works on hi speed it is the blower motor resistor that is bad. The blower motor resistor is located under the passenger side of the dash next to the blower motor. It is not necessary to remove the blower motor to change the resistor.
May 12, 2009 | 2005 Kia Sorento
The External Temp sensor on my 2004 Kia sorento is inop
External temp sensor is located in front of ac condensor lower part.
Feb 02, 2009 | 2004 Kia Sorento
2004 kia sorento no heat
I had a similar problem with AC & Heater fan,it works on and off, and sometimes if the road was rough it runs, So I had to remove the fan clean it with a blower from dust and debris, then I installed it back and it is running ever since for more than a year without having to replace it.
Dec 08, 2008 | 2004 Kia Sorento
Heating & Cooling Logo
173 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
