SOURCE: Unable to create recovery disk.
Hi there.
Sounds like the software could be corrupt, but there is an easier way to create a recovery disk, check this tutorial out >>>>>
http://createrecoverydisk.com/
If you need more advice please feel free to post back.
Good luck and thanks for using FixYa!!
SOURCE: Restore Original Configuration
If you have not yet found time to call Toshiba and get the recovery CD you may try the following:
1. Reboot you system
2. Press F1 (immediately you get options to press F2 and F12)
3. Press F8 (this will give you more options including system recovery)
Please ignore if you already have the CD. Having the CD is the best as previously said.
The step above have helped me many times to avoid doing factory system restore. I hope it helps you or someone else.
SOURCE: can i record songs on to a cd from my toshiba L305-S5919?
Yes
You get a copy of a program called Nero Burning load that onto your laptop and that allows you to create a cd of music with different formats such as .wav .mp3 etc
Go to www.filehippo.com and look at their selection
SOURCE: Trying to use Toshiba "recovery Disk creator"
u need a blank dvd, or tell the program your using regular cd, it will be like four dvd's or like 11 regular disks. in some cases it wont work with either, i have seen it where the program just doesnt know any disk is inserted or blank. if thats the case, update the program or contact toshiba
SOURCE: SD Card reader 4gb driver needed
try this one....copy and paste to your browser and click 2nd page, Click on Driver Flash Memory SD, click on download.Once you have downloaded the file, Double click the file and it will self install. Follow the prompts.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2226352&rpn=PSLC8U&modelFilter=L305D-S5922&selCategory=3&selFamily=1073768663
