Sounds like the automatic circuit protection. Check to make sure you have good speakers and NO shorted wires to them. Too many spearkers conected to the outputs will cause the same problem.
there is 3 small circular sockets on the back of your pc they are coloured pink, light green and green or black plug your speakers into the light green one if that doesnt work try the other sockets one of them should work and dont forget to turn on the speakers usually the power button is on one of them...or if you dont have speakers try plugging the cable with the light green on both ends one end into the back of pc and the other end into the back of screen you might have to locate it where you see the connection cable on back of screen it might be hidden up under that part of screen ...good luck hope this helps
We bought a while back a surround sound system with a SONY Dolby Digital FM Stero FM/AM Receiver STR SE501, a small subwoofer and small centerband spearker.
We recently upgraded to two better and larger submwoofer and centerband speark:
ICON VC25 CENTER SPEAKER (SN 100987108520533
SW-350 SUBWOOFER (SN 101043809321322
Problem we are having is, when we turn the TV on in the morning, about 10 minutes, we hear a click noise in the receiver, a pop loise in the subwoofer, and the it cuts of the speark. It with click again, cuting the spearker back on, then do it agian and cut them off. It seems once it does this a few times, and comes back on, it stays on the remainder of the day.
What is the problem? Do we need to make an adjustment to the receiver, because of the upgrade. We original had moster cables. Do we need to replace them?
Hope you can help. Tony ([email protected])
First of all what exactly do you mean by "changed the CPU"? If its the processor? Is only the display not working, since you have said that the fan runs, it means the PC is starting. Check the Keyboard & mouse PS2 jacks. If there is any bent pins in the jacks? If so gently straighten with a pair of tweezers. Also try using a working Keyboard & Mouse from any other PC. If that still does not work, do you see the led lighting up on the MB? Does the MB make beeping sounds? How many? ALso mention the processor you have so that we may be able to help...............sodeep
Reset the laptop. Take out the battery and remove the power cable from the wall socket. Wait 30 seconds and put the battery back in, connect it back to the wall socket and start it up.
