Question about Motorola Mobility RAZR V3
My Motorola V3c will fully charge the battery in about 15 minutes. But the charge lasts maybe 3-4 hours. It is a new phone.
  • 1,029 Answers
First, check the battery connection. the little metal spots where the phone and the battery connect. take out the battery and dip a q-tip in rubbing alcohol and swipe them clean and have the battery tested. It simply could be a shot battery,or low battery life and testing it will at least confirm or eliminate that possibility.phone's batteries are only meant to last for about a year. so if you bought a new battery/phone and it still wont hold a charge for long , then replace a new battery or return the phone for replacement since it should still be under warranty
Posted on Oct 08, 2009
  • 416 Answers
Moto Razr components where taken off the assembly line years ago and all parts used are refurbished or stockpiled.........you have a bad battery, case closed........the razr has a few common flaws...... ear piece, LCD, and battery tends to go out without notice and on a rare occasion wont work right out of the box.....Working at Sprint PCS I saw 1 out of every 15 Razrs have problems straight from the box....take the phone back to the staore and they will giv you a new battery as they should be away of the hiccups associated with this device!!!! :D and by the way, 3-4 hrs use from a 15 min charge is awesome.......just your battery has an internal flaw that is causing it to transfer too much power.....(i.e. thats how it is able to charge so fast, but also why it dies so fast) if you have another razr laying around try that battery as long as the lettering on the battery is the same....fr example : a battery with the code bt50 and br50 are not interchangeable.
Good Luck and pls rate this post!!!! :D
After fully charged battery power lasted about 20 minutes.
Since it's brand new, return it. You didn't say what type of tablet it is, but they should last for many hours on a charge.
Oct 02, 2015 | Tablets & eReaders
How long should my battery last? I bought an nintendo DS lite and I forgot to ask?
Hello there, the Nintendo DS Lite has four levels of brightness. The battery will last 15-19 hours on the lowest settings, and 5-8 hours on the brightest.This can also vary depending on the type of game activity."
So the DS should last the whole time in even on the highest brightness settings, if fully charged. Nintendo states that it takes 3 hours to fully charge the DS.
hope this helped, also this site will also help you to get your ds battery to last for longer
 http://www.ehow.com/how_2015000_extend-b…
good luck
Apr 21, 2010 | Nintendo DS Lite
We had a new battery it Razr/V3c and the phone is working but try to charged the battery and it say "unable to charged" i need to know why it not working.
hi ... i think your battery charge is gone under minimum limit ... Please try charging your mobile with another battery and try to switch on your mobile and after five min remove the battery, charge with your battery and see whether its charging or wat??
May 30, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Batter life in the second season
When batteries are only used seasonally, and they are stored, they can become damaged from weather or from storing them when they are not fully charged. In general, batteries used seasonally will have a shorter lifespan, so it sounds like you likely need a new battery. Check out http://www.batteryinternational.com/electric-lawn-maintenance-batteries.html for a replacement, and be sure to charge it fully before storing.
May 19, 2009 | Remington PowerMower 17-Inch 60-Volt...
My V3c motorola phone will not hold battery charge
A normal battery only last between 300- 400 charging cycles, If you have had the phone more than a year time to get a bew battery, if less than a year check with your cellular provider to see if you battery has a limited warranty
Dec 09, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Battery will not charge with a new RAZR V3C phone
the usb charging port may need to be service or replaced so it would be best to take the phone to a mobile repair and have it done.
Nov 05, 2008 | Motorola Mobility RAZR V3c Cellular Phone
My motorola krzr only stays on for a few minutes after a full charge.
Yes, you should resort to a new battery, coz the old one is exhausted. Overnight charging is not a good habit. You should charge 2-3 hours until full, and remove the charger
Sep 27, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
Battery issues
the mainboard on the phone is faulty and needs to be replaced.
Aug 19, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
131 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
