Question about Denon AVR-1403 Receiver
DENON 1403 NO SOUND, ITS ON ANALOGUE INSTEAD OF DIGITAL, THINK THE KIDS PRESSED A BUTTON HEEEEEEEEELLLLLLLLLLLPPPPPPPPPPPP JUST GOT NEW DVDS FER CHRISTMAS, ALL ELSE WORKS TUNER ETC
Press the "input mode" button, ought to solve it
Posted on May 21, 2008
Hi pressed a button on my Denon remote and have now lost sound out of 2 of my 5 speakers. Don't know what I pressed can you please help. Thank you
I would guess it's the Surround Sound mode button. Various modes in Surround Sound do not use all 5 speakers. Often the button pressed repeatedly changes between the modes. So if you press it again it might restore the sound mode to the one you had. I can't be more specific as you did not give the model number.
You could try the Denon website to see if they have a free PDF of the user manual, if you have lost it. You will need the model number for that though.
Jun 05, 2017 | Denon Audio Players & Recorders
Denon 3802 connected to blu ray player but playi g dvds, how do i get dd 5.1?
You cannot get 5.1 sound from DVDs that are not encoded with 5.1 sound. They may be stereo, which will only send sound to the main front L/R speakers.
Nov 23, 2013 | Denon AVR-3802 Receiver
How to connect Denon avr 1804 connecting to roku hd
I connected by Roku to a Denon 1804 Receiver this way:- I plugged the cable that came with the Roku into VCR2 input jack of the Denon. (I used VCR2 because it was available).- Using the remote from the Denon, I made sure the slide switch was on "Audio." (See page 20 of Denon Manual).- I pressed pressed the System Setup button- *System Setup appears in display of Denon- Using the cursor buttons I scrolled to menu Digital in Assignment- I set Menu item 16 Coaxial to VCR2 since that was the input jack I used for the Roku. - After making the selection press the CH Select Enter button to save- To exit the System Setup press the System Setup button again- When using the Roku, select the input source as VCR2 (or whatever jack you used). You should now have sound through the Denon.The most important step is to read the Denon manual starting on page 20
Dec 08, 2012 | Denon AVR-1804 Receiver
My Denon AVR1611 powers up and the TV sound works just fine, but after 5 seconds or so the sound quits and I have to press the quick select sat/cable button to start it up again.
hi,
There are two types of input for sat/cable in your amplifier. One is the Digital input and the other is the Analogue input. You didn't specified which one is currently used by you.
However, if you connect the digital input then you have to configure the input assignment to digital and for analogue input configure as analogue.
If you use analogue input and input assignment is in digital mode then the problem mentioned by you can occur.
First of all check the input assignment for sat cable. for that do the following
1. Press the menu button on the amplifier's remote.
2. Select input setup
3.select input assinment ( check the input assignment for sat/cable, If you are using the analogue
input select it as analogue,if your are using the digital input then select it as digital.
ok
Feb 17, 2011 | Denon AVR1611 5 Channels Receiver
Denon AVR-1403 receiver switched from digital to analogue.
There are three modes (Auto, DTM, and PCM) on the input mode switch, on the main unit, selected by repeatedly pressing the input mode switch.
However, if you have already depressed the Analog button in, on the main unit you have predetermined the mode as analog.
On the remote, the INPUT MODE switch combines toggles for 5 choices, [Auto, PCM, DTS, Analog,
Ext. input]
My guess is that either the input mode switch on the main unit and/or the remote are toggled to analog.
Apr 11, 2009 | Denon AVR-1403 Receiver
Denon AVR-1403 connected to DVD can hear music but no dialougue!!
Check the center channel speaker and the surround sound audio settings. If you do not have a center speaker, it needs to be set to off on the receiver.
Jan 19, 2009 | Denon AVR-1403 Receiver
Pressed the wrong button when setting up new sharp acquos 46 in lcd tv.
You might try pulling the AC plug out and leaving it overnight. Since many sets are now using a little flash memory that does not require constant power to remember stored settings, this may not work.
Nov 01, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Denon avr-1403/483
Denon AVR-1403/483One of the speakers when connected trips the units power off.
Disconnected it and it works OK without that channel. Connected a different speaker and wire to that channel and it does the same, trips power off. It's acting like a when two wires are shorted. This is not the case as I have tried different wires and speaker. Not sure whats going on. Presently running system without that channel. Hope someone has an idea.
Oct 19, 2008 | Denon AVR-1403 Receiver
Can Denon AVR-1403 take 250 volts AC power?
no it will be damged need hi end monster power strip hd700 or better off ebay that will go 1st and alarm will sound on it
Jan 10, 2008 | Denon AVR-1403 Receiver
Denon AVR-1403 Receiver Logo
153 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
