Question about Zenith B27A11Z 27" TV
We are trying to hookup to cable. The TV screen
We are trying to hookup to cable. The TV screen shows Video/Time/Stereo. Cannot access any channels past 12, channels up/down is not compatible to the cable because it goes back to video/time screen.
  • 454 Answers
TV is in antenna mode, enter the setup menus and put in cable mode.
Posted on Oct 08, 2009
I unhooked my PS3 from one tv and now another tv recognizes it but has no picture or sound. bought new wires and still nothing. what is my next step?
Try resetting the video output settings. They may not be appropriate for your new tv.
Press and hold the power button until you hear two beeps while it is off.
Jun 14, 2014 | Sony Playstation 3 (PS3) Console
Why arn't i getting a picture on my snes
Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
Make sure the system has power. If not, go to the No Power Light instructions.
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position.
Important Note: Inserting the game with the Power ON may result in a blank screen. Always turn your system OFF before inserting or removing Game Paks
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If the above troubleshooting doesn't fix the problem, click here.Note: pictured above is the redesigned Super NES. The original Super NES uses the same hookup steps listed below.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the Stereo AV cable into the Video "in" on the back of the TV. Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono television with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV cable into the "multi out" connector on the back of the Control Deck.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Slide the Power Switch on (toward Game Pak).
Turn on the TV and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Mar 29, 2013 | Nintendo Super NES Console
I have the first nintendo nes and i dont have the rca's i have the one you hook through the cable and it comes on but i cant find the channel to put it on to play the game ! What am i doing wrong ?
Original-Style Super NES RF to TV Hookup
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen. You are ready to play!
Nov 25, 2011 | Nintendo Super NES Console
Ive just plugged my super nes in after a good few years without use, but theres no sound. the picture is perfect though. any ideas what the problem may be?
Check your system connections to ensure they are firm and correct.
Remove and reload the Game Pak, pressing firmly to ensure it is locked in place.
Many Game Paks have an option that controls one or more volume variables. These may have been set to maximum volume during the manufacturing or testing process. Consult the game manual for directions on how to adjust the settings. You can usually get to them by going into the Options screen.
Remove the AV cables and reinsert them with a slight twisting motion. Make sure the Video Cable (the yellow plug) is in the video input. Plugging it into an audio input will cause buzzing. Also, make sure none of your audio (red) cables, are plugged into a phono jack on your stereo, which can also cause buzzing. Finally, make sure the Stereo AV Cable is plugged into input ports, not output ports. For a detailed review of the hookup, please check our hookup instructions.
Some TVs or VCRs may have special Audio Inputs that don't allow the volume to be controlled by the TV. They are intended to be controlled by a different device, such as a home theater amplifier. Check your manual for the TV or VCR to see if this is the case for your unit.
Some TV and VCRs have a small switch, usually found near the AV inputs, that is used to allow components to send sound out to the TV speakers. Check your manual for the TV or VCR to see if this is the case for your unit.
If you are using the Stereo AV cable for your hookup, remove the plugs and reinsert them with a slight twisting motion. Make sure that you are plugging the yellow cable into the video input, and that the audio cables (red and/or white) are plugged into the audio input jacks on your TV or VCR.
If you only have one audio input, and one plug is hanging, that will result in a loss of sound. Either purchase a Y-adapter or access the game's option menu, and when available, set the game sound option to Mono.
Click here if the troubleshooting doesn't help
RF Hookups
Try switching both the TV and RF Modulator to a different channel (3 or 4). Try adjusting the Fine Tuning control on your TV to see if it clears up the sound. A particularly strong TV station (or cable TV) signal may be broadcasting on Channel 3 or 4 in the area, causing interference. For a detailed review of the hookup, please check our hookup instructions.
Try disconnecting the antenna/cable wire from the RF Switch. (You will have to reconnect it again for regular TV viewing.) If this option works, an AB Box may be needed. These can be purchased at various home electronic stores.
See below if the troubleshooting doesn't help
What to do if Troubleshooting doesn't help
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product. If you simply need to order parts or accessories, you may want to check out our Online Store. Nintendo's Online Store still carries many parts and accessories for our older products.
Jan 13, 2011 | Nintendo Super NES Console
My super nintendo has no sound and I replaced the sound module and still no sound please help !!
RF Hookups
Dec 03, 2010 | Nintendo Super NES Console
I found a SuperNintendo that has been in our attic for many years, however when I conect it upo my TV cannot find the output from the SuperNintendo when it does a search. What frequency or channel does it...
If after following these directions you are not able to view the game, try our Troubleshooting Tips. Note: pictured above is the redesigned Super NES. The original Super NES uses the same hookup steps listed below.
Installation Steps:
Nov 27, 2010 | Nintendo Super NES Console
How to hookup
It depends on the TV connectors. The most common is to use either the AV or S-video. In both cases you carry the video signal on one cable (either an RCA plug (yellow) or a S-video). Plug this into the appropriate video in on the TV. Then you can connect the audio. If you use the TVs speakers or a stereo receiver or amplifier, use a 2-plug (or a 3-plug including the RCA video) on each end wire (red and white for the audio) with the white wire carrying the left audio. Connect this cable to the audio outputs labeled Front on the left of the DVD player. If your TV uses PAL signal you will need to set the audio to 2-channel and the Down-Mix to Lo/Ro. Both are accessed from the On-screen menu or the buttons on the remote when a disc is in the player. The Down-mix is in Preferences 2 (Zoom + on the remote) and the Audio Channels is in Speaker Settings (Zoom - on the remote).
If you are using a multichannel (5.1) speaker system, use a couple of extra audio cables and match them to the speakers input ports (center, subwoofer, rear left and right). Set the Speaker settings appropriately. If your receiver can handle digital audio output, you can use that (get a cable) and modify the Preferences 2 section for digital audio.
If your TV doesn't have A/V inputs, you will need a converter. (If you only have RF (coax) in, get a RF modulator.) These are available at many stores.
I hope this helps.
Aug 14, 2010 | JVC XV-D723 DVD Player
NES system doesnt work with my t.v.'s. i have plasma samsung and a symphonic 20" older t.v. that it doesnt work on either can you tell me what to do?
NES to TV Hookup
Installation Steps:
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the NES (labled RF Out).
On the back of the NES, set the 3/4 switch so that it matches the channel of the TV.
Press the Power button on the front of the Control Deck.
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Aug 06, 2010 | Nintendo NES Console
Rca model f36649 s-video hookup to laptop computer When I hookup s--video cable to tv & HP Pavillion dv9000. I get nothing on tv? I have tried putting tv on channel 3.
Depending on how many hook ups you have on your tv it may have a factory designated channel. Example: Video 1, Game, etc. I know my TV has several different video channels. It's more a matter of trial and error until you find the vidoe channel for your oulet. Input channels are usually found before channel 1. Or look on your remote and see if it has a button to switch the channel to your input channel. Good Luck.
May 27, 2010 | RCA F36649 36" TV
Zenith B27A11Z 27" TV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
