Question about Yamaha RX-V661 Receiver
The front Display of my RX-V661 is not readable. after a night of being turned off, it lights up for a short period before going off (it does not display anything at all) I tried resetting it, but since i can't read the menu, its impossible to do so
There's a common problem with the Rx-V661 where a capacitor blows and then the display on the unit no longer works. It will start to display when you first turn it on, but fade out right away. This is because of a blown capacitor and a known issue for the Rx-V661.
Posted on Dec 17, 2009
  • brianpaul9 Dec 17, 2009
Yamaha RX-V661 LCD / Front panel.
Symptom: when you first turn it on, you can see a VERY little light but after 5 sec, you cannot see it anymore or for most of us, we started using a flash light. Here is the summary of the solution and I know that it works because I fixed it today 3/16/2011, 30 minutes ago. As many pointed out that there is a "light" 12v - 14v in the back but there is NONE. How do I know? I listened and searched and there are NONE. The whole LCD in the front is air seal like a light bulb so it
is a light bulb already. Also, you might see a little burn/gray smoke on the left hand side, don't worry about it
because if the light comes on, it still works but not enough power. If the LCD is broken, please don't try buy the part and replace it because by the time you read this, the part and labor cost as much as buying a new one (on eBay and not Best Buy).
Problem: in the middle of the unit near the back near the "surround sound back", there are 3 capacitor rated at (2 units) 35v 220uf 85'C and (1 unit) 50v 220uf 85'C. What Yamaha did wrong, base on my guess is that they put the 85'C too close to the heat sink. The heat causes the capacitor to slowly blown that is why you still get your power to the LCD but not enough.
Solution: remove the top, unscrew EVERYTHING in the back and there are about 20 ~ good luck. For those that don't have good memory, please take pictures. There are many plugs inside that you need to unplug before you can remove 1st layer (audio/ video input) 2nd layer (HDMI and Optical input), the last layer you will see 3 capacitors that are kind of "blown" up (google "bad capacitors" pictures or video). Remove them then replace them, which you can Google this on tube and they should teach you how. It was very easy for me but then again, please don't try to do it if you cannot even change your car oil or build a computer because I believe that is the difficulty level.
solder iron: $9-$20 get it on eBay or radio
shack
(2 units) 35v 220uf 105'C and (1 unit) 50v 220uf 105'C or what I got was (3 units) 50v 220uf 105'C - they are about $0.50 to $2.00 each
I keep the 220uf the same to be safe but increase the voltage and heat to increase the life of the capacitors.
Good luck everyone,
Posted on Mar 17, 2011
  • jimmyscw Mar 17, 2011
    I tried to post a picture but it didn't up load...thank you fixya from great website design. Anyways, if you took the risk to open up your AV that far, 1) you are smart enough already or 2) the unit has been destroyed by you in the process because you are a noob.
    Below is the video from the 0:05 to 0:20 seconds - JimmySCW
    http://www.youtube.com/watch?v=oDGjWOabJ...
  • msullinger
    msullinger Jan 07, 2013
    I just had an engineer friend replace these 3 capacitors and it worked! Thanks so much for posting this fix.
You cannot get the osd to display when you go into the advanced set up by holding the tone control and turning on the master on/off and therefore cannot see any display to reset the system. Could someone post the number of clicks when turning the Program dial and number of key presses for the tone control to do the full reset. We are operating completely blind. Thanks!
Posted on Nov 27, 2009
    Scholar:
  • 131 Answers
Try resetting this unit thru your osd on your television
Posted on Oct 09, 2009
Wrong remote
no but you can change the settings from the front panel of the unit.
Feb 12, 2014 | Yamaha RX-V661 Receiver
The receiver works great but there are no longer any lights on the front. We checked the manual and can not see where there is a fuse or light bulb to change help
If on the front display it is either missing a voltage source (connection or bad part) or the display itself is bad.
Nov 08, 2012 | Yamaha RX-V661 Receiver
I have a RX-V661 that turns off within a second or two of turning on. Is the capacitor the problem and, if so, how can I replace it ?
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 06, 2011 | Yamaha RX-V661 Receiver
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
Yamaha front panel display dim
because if the light comes on, it stills work but not enough power. If the LCD
is broken, please don't try by the part and replace it because by the time you
read this, the parts and labor cost as much as buying a new one (on eBay and
not Best Buy).
those that don't have good memory, please take a picture. There are many plugs inside
2nd player (HDMI and Optical input), the last layer you will see 3 capacitors that
shack
Good luck everyone,
May 29, 2009 | Yamaha RX-V661 Receiver
Display problem RX-V661
Contact Yahama's customer support group on the web is one way to order one...accordianman
Sep 08, 2008 | Yamaha RX-V661 Receiver
RX-V661 front display problem
Excess power supply demand from the display can cause the symptoms you describe. Unfortunately, the fix will be a new display if this is the case...accordianman
Jun 16, 2008 | Yamaha RX-V661 Receiver
No display info on receiver
Try plugging a video monitor AKA your TV into that monitor output connector on the rear of the yamaha.
Select video in on the TV and see if anything shows up from the yamaha
Sounds though like the receiver has serious issues. If you can get your moeny back , do so
Feb 24, 2008 | Yamaha RX-V661 Receiver
Display Screen Goes Out
Whats wrong is a bad capacitor. This is why when you turn it on you see the display for a little while, then it start to fade away. Unless you have a wiring diagram for this unit and know how to solder, your going to have to take it in for repair. You can try to check every capacitor, but have you seen how many capacitors are in that baby!!!! I hope this help. Good luck!!
Jan 03, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V661 Receiver Logo
790 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
